    COFFEE Undo Not Working In R10.x
    3 Posts 0 Posters 379 Views
      On 05/11/2007 at 05:18, xxxxxxxx wrote:
      Cinema 4D Version:   10.x
      I am trying unsuccessfully to have COFFEE undo the creation of a base tag in R10.x.
      Undo calls work perfectly in the following example in R9.6 but have no effect in R10.x. (This code goes into a COFFEE expression tag with a Boole user data element to trigger creation of a display tag.)
      > _
      > main(doc, op)
      > var ttag = op- >GetFirstTag();
      > while(ttag->GetType() != Tcoffeeexpression)
      >     ttag = ttag->GetNext();
      > var addTag = ttag#ID_USERDATA:1;
      > doc->StartUndo();
      > if(addTag)
      >     var dispTag = AllocTag(Tdisplay);
      >     op->InsertTag(dispTag);
      >     doc->AddUndo(UNDO_NEW, dispTag);
      > ttag#ID_USERDATA:1 = FALSE;
      > doc->EndUndo();
      > _
      Can anyone tell me why this is not working in R10.x?
        On 05/11/2007 at 05:36, xxxxxxxx wrote:
        To be honest this loks like a hack. You shouldn't create nodes (object/tags/materials, etc.) from within an expression. An expression plugin with an interface where you can catch a button message is probably a better idea because this happens outside of the expression.
          On 05/11/2007 at 15:30, xxxxxxxx wrote:
          Thanks for the guidance, Matthias. Looks like I'll have to create an interface for the plugin. Björn mentioned this on the CGTalk forum a couple of years ago too but I had forgotten.
