    Add item to Multi-Pass List
    3 Posts 0 Posters 295 Views
      On 27/10/2007 at 17:33, xxxxxxxx wrote:
      Cinema 4D Version:   10.111
      How would I add an item to the Multi-Pass list (for example, the Reflection channel) in the Render Settings?
        On 29/10/2007 at 08:14, xxxxxxxx wrote:
        Here is a function that I wrote to insert a multipass channel into the render settings:
            BaseContainer* HybridMPChannel(LONG multipassChannel)
            RenderData *renderData = GetActiveDocument()->GetActiveRenderData();
            if(!renderData) return NULL;
            BaseContainer *rdata = renderData->GetDataInstance();
            if(!rdata) return NULL;
            BaseContainer bc;
            BaseContainer *multipassData = rdata->GetContainerInstance(RDATA_MULTIPASS_CHANNELS);
            if(!multipassData)
            GeData *mChannels = rdata->InsData(RDATA_MULTIPASS_CHANNELS, GeData(bc));
            multipassData = mChannels->GetContainer();
            if(!multipassData) return NULL;
            GeData* d = multipassData->InsData(multipassChannel,GeData(bc));
            BaseContainer *channelData = d->GetContainer();
            return channelData;
            BaseContainer *buffer = HybridMPChannel(VPBUFFER_REFLECTION);
            buffer->SetBool(RDATA_MULTIPASS_ACTIVE, TRUE);
        You can find all of the defined LONG's for the different mp channels in the RenderData class of the SDK.
        Josh
          On 30/10/2007 at 00:00, xxxxxxxx wrote:
          Thank you!
          That's very helpful.
