    get face number count for geometrics
    4 Posts 0 Posters 458 Views
      On 26/10/2007 at 02:08, xxxxxxxx wrote:
      Cinema 4D Version:   9.5
      I want to find out and get the face number  of count result and vertex number .... but I have a little trouble that  my code can't get back the correct result :
      my code:
      void GetAllPolygon(AtomArray *oPolygons,BaseObject *oPolys)
           if(oPolys)
         //MessageDialog("GetType Begin");
         if( oPolys->GetType() == Opolygonn ) //||( oPolys->GetType() == Ocylinder)||( oPolys->GetType() == Ocube)||( oPolys->GetType() == Osphere))
          oPolygons->Append(oPolys);
               if(oPolys->GetDown())
          GetAllPolygon(oPolygons,oPolys->GetDown());
         if(oPolys->GetNext())
          GetAllPolygon(oPolygons,oPolys->GetNext());
        // MessageDialog("GetNext End");
      LONG GetAllPolygon(AtomArray * oPolygon)
           if(!oPolygon)
         //MessageDialog("Alloc AtomArray Fail that Can't get polygon ");
         return 0;
           BaseDocument *doc=GetActiveDocument();
           BaseObject *obj = doc->GetFirstObject();
           if(obj)
          //MessageDialog("To  get polyon ");
                GetAllPolygon(oPolygon,obj);
           return oPolygon->GetCount();
      void SnapPolygonData( AtomArray *oPolygons, LONG lPolygonCnt, LONG& out_iFaceNumCount, LONG& out_iVertexNumCount)
       LONG nCount = 0;
       if ( lPolygonCnt == 0)
        return;
       //MessageDialog( LongToString(lPolygonCnt) );
          for(LONG i = 0;i < lPolygonCnt; i++)
              PolygonObject *obj=(PolygonObject* )oPolygons->GetIndex(i);
              //MessageDialog(obj->GetName());
        if ( !obj) break;
        LONG lngFace = obj->GetPolygonCount();
        LONG lngVertex = obj->GetNgonCount();
        out_iFaceNumCount += lngFace;
        out_iVertexNumCount += lngVertex;
      bool GetMetaData( LONG& out_iFaceCount, LONG& out_iVertexCount )
        LONG iFaceNumCount = 0;
       LONG iVertexNumCount = 0;
       AtomArray* oPolygons = AtomArray::Alloc();
       if ( !oPolygons )
        MessageDialog( "AtomArray Alloc Is Fail" );
        return false;
       //MessageDialog( "AtomArray Alloc Is Succuss" );
          LONG lPolygonCnt = GetAllPolygon(oPolygons);
       SnapPolygonData( oPolygons, lPolygonCnt, iFaceNumCount, iVertexNumCount);
      out_iFaceCount = iFaceNumCount;
       out_iVertexCount = iVertexNumCount;
      AtomArray::Free(oPolygons) ;
       return true;
        On 26/10/2007 at 05:10, xxxxxxxx wrote:
        where in your code do you run into problems?
          On 28/10/2007 at 17:58, xxxxxxxx wrote:
          that can't to get polygon object and count face number back when I had  added cube to  scence after. show me the result of polygon's face and vertex number is 0;
            On 02/11/2007 at 04:49, xxxxxxxx wrote:
            It seems you don't convert your primitve objects into polygon objects. For instance you have first to convert the cube into a polygon object to access the polygons. The savest way to it is by using SendModelingCommand() to get the current state of your object. Here a little example.
            > _
            > Bool MenuTest::Execute(BaseDocument *doc)
            >      StopAllThreads();
            >      BaseObject *op = doc->GetActiveObject();
            >      if(!op) return TRUE;
            >      BaseObject *res = NULL;
            >      ModelingCommandData cd;
            >      cd.doc = doc;
            >      cd.op = op;
            >      if(!SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, cd)) return FALSE;
            >      res = static_cast<BaseObject*>(cd.result->GetIndex(0));
            >      if(!res) return FALSE;
            >      if(res->GetType() == Opolygon)
            >           GePrint("point count "+LongToString(ToPoly(res)->GetPointCount()));
            >      return TRUE;
            > _
