    bitmap button (the 99.)
    7 Posts 0 Posters 536 Views
      On 17/10/2007 at 02:29, xxxxxxxx wrote:
      Cinema 4D Version:   9.5
      Hi!
      I (desperately) try for some time now to get a working bitmapbutton in the active-object-manager.
      xxxx.res -->
           BITMAPBUTTON  RETRO_TEST{  BORDER; BUTTON; } //// RETRO_TEST==9000900
      <--xxxx.res
      xxxx.h, xxxx.xpp------->
        class T_retro_main : public ObjectData
          Bool Init(GeListNode* node);
          Bool Message(GeListNode* node, LONG type, void *ptr_data);
        Bool T_retro_main::Init(GeListNode* node)
          BaseContainer *ptrcont = GETDATACONTAINER_INSTANCE(node);
          BitmapButtonStruct *ptr_bbs = BitmapButtonStruct::Alloc();
          if(ptr_bbs)
            ptr_bbs->op = (BaseList2D* )node;
            ptr_bbs->id.SetId( DescLevel(0x4711 , DTYPE_BUTTON /*?*/ , 0x00110011 ) );
            GeData gedata2 = GeData(CUSTOMDATATYPE_BITMAPBUTTON,*ptr_bbs);
            ptrcont->SetData(9000900,gedata2);// RETRO_TEST==9000900
          return(TRUE);
        Bool T_retro_main::Message(GeListNode* node, LONG type, void *ptr_data)
         switch(...) ........
         case MSG_DESCRIPTION_GETBITMAP:    //<-------this does happen one or two times
                 DescriptionGetBitmap*dgb=(DescriptionGetBitmap* )ptr_data;
                 .......alloc/compute bitmap mybm etc...
                 dgb->bmp=mybm;
      <------- xxxx.h, xxxx.xpp
       that displays a bitmap in aom.
       if the button is pressed nothing happens, no message nor something else except MSG_DESCRIPTION_GETBITMAP again.
       Is this the way to detect a pressed button?
       Somewhere there is a hint that there exist something like:
          class BitmapButtonCustomGui : public BaseCustomGui<CUSTOMGUI_BITMAPBUTTON>
            void SetCallback(const BitmapButtonCallback& cb);
       which looks very promising. Unfortunately I cannot find a way to get this wonderful thing.
       I cannot find any connection between a xyz..CustomDataType and the corresponding xyz..CustomGui.
       (to be honest, I cannot even read that stuff without getting confused).
        On 18/10/2007 at 03:15, xxxxxxxx wrote:
        Here an example how to catch the BitmapButton.
        > _
        > Bool LookAtCamera::Message(GeListNode *node, LONG type, void *data)
        >      switch (type)
        >           case MSG_DESCRIPTION_POSTSETPARAMETER:
        >                DescriptionPostSetValue *dc = (DescriptionPostSetValue* ) data;
        >                if (dc->descid[0][0].id == LOOKATCAMERAEXP_BUTTON )
        >                     GePrint("button");
        >      return TRUE;
        > _
          On 18/10/2007 at 06:00, xxxxxxxx wrote:
          Hi!
          Thanks for answering, I nearly thought, the question is too trivial.
           >>  Bool LookAtCamera::Message(GeListNode *node, LONG type, void *data)
           >>       switch (type)
           >>            case MSG_DESCRIPTION_POSTSETPARAMETER:
          ...unfortunately never happens. Maybe because it is a feature which appears in sdk-version 10.
          I am working with (yes I am somewhat behind developements) sdk-version 8.5, cinema-9.5
          But "bitmap button" is so old.
          The programmer must have had a plan as he (she? they?)  wrote that stuff.
            On 19/10/2007 at 13:05, xxxxxxxx wrote:
            I think you are stuck without it then. It seems that full BitmapButton support in the AM is only realized in R10. MSG_DESCRIPTION_POSTSETPARAMETER is only defined in R10 (yes, I searched the _api folder of earlier versions). You could check for a type == 19 and see if it works in R9.5 but wasn't full fleshed out (?)
              On 19/10/2007 at 19:54, xxxxxxxx wrote:
              Hi!
                > You could check for a type == 19
              I did of course.
              Its helpful to know that all trying could be in vain.
              So it will be an alternative solution.
              One button and a bitmap to the left.
              I will search the sdk-help-board for a solution
              to have that bitmap updated when the user presses the button.
              (I strongly believe, that no programmer will release
              something, that does not work entirely. So there must somewhere
              be some functionality left).
              Thanks!
                On 19/10/2007 at 23:36, xxxxxxxx wrote:
                Hi!
                  (Bitmapbutton <-> how to know that user clicked on)
                If someone is interested. Mikael Sterner knew it some years ago.
                Search for "Sorry if any previous post was misleading."
                  On 20/10/2007 at 08:49, xxxxxxxx wrote:
                  An odd place to check for a button click (usually this is done in MSG_DESCRIPTION_COMMAND), but who am I to argue with Mikael with respect to Bitmapbuttons. 🙂
