    Emitter Position Change Not Rendering
    5 Posts 0 Posters 546 Views
      On 16/10/2007 at 02:09, xxxxxxxx wrote:
      Cinema 4D Version:
      I have tried to change the position of the first particle in the Emitter with
      tag = Emitter Object->GetFirstTag();
      movePosition = tag->GetData();
      movePosition[0] = vector(0,250,0);
      tag->SetData(movePositon);
      tag->Message(MSG_UPDATE);
      it works in the ViewPort Render but not the Picture Viewer
      Please Help
        On 16/10/2007 at 16:48, xxxxxxxx wrote:
        I think you can be helped by this Thread
        Basicaly you need to search a specific tag, not only the first.
        When rendering Cinema render a copy of the document and there are hidden tags that can be infront of you tag.
        Lennart
          On 16/10/2007 at 17:10, xxxxxxxx wrote:
          As Lennart mentions, the Polygon and Point tags are hidden tags that always exist on Polygon/Point objects. Other tags may be hidden as well (Claude Bonet weight tags, plugin tags, etc.) Never assume that your tag is first! ...deceptive isn't it...
          Best to do a loop:
          for (tag = obj- >GetFirstTag(); tag; tag = tag->GetNext())
               if (tag->GetType() == type) continue;
               // This tag is of type, do something
               break;
          This can be used, of course, to consider ALL tags of a particular type by removing the break line.
            On 16/10/2007 at 21:25, xxxxxxxx wrote:
            And that should be if (tag->GetType != type) continue; - duh
              On 17/10/2007 at 07:55, xxxxxxxx wrote:
              Thanks tcastudios & kuroyume0161 that worked
              It would have taken me forever to find out that that was the problem
              Thanks again for you Knowledge of Cinema4D's Coffee
