    how to get an set frame scene effect?
    4 Posts 0 Posters 457 Views
      On 08/10/2007 at 00:54, xxxxxxxx wrote:
      Cinema 4D Version:   9.5
      ---------I want to get and set this effect that object is full in the active viewport  like to frame scene menu function under the "edit",  how  to implement it using C++ code?   thank you for your help in advance?
        On 08/10/2007 at 01:23, xxxxxxxx wrote:
        CallCommand(12288) should do the trick. Just get the IDs for the commands from the Command Manager in Cinema 4D.
          On 09/10/2007 at 00:27, xxxxxxxx wrote:
          by the way? how about the CallCommand(xxxxx)  for  frame scene without  camera/light .
            On 09/10/2007 at 03:04, xxxxxxxx wrote:
            Please read the SDK documentation. You pass the Command ID as parameter to the CallCommand() function. You find these IDs in the Command Manager.
