    CAWeightTag GetJoint() not working ??
    4 Posts 0 Posters 468 Views
      On 26/09/2007 at 09:16, xxxxxxxx wrote:
      Cinema 4D Version:   R10
      Platform:      Mac OSX  ;
      Language(s) :
      I'm having trouble getting joint references from a CAWeightTag.
      I can get joint count, weight count, and weights themseves, but not a reference to a joint.
      using wtag->GetJoint(i, NULL ) should return a joint ref, but fails, I have tried passing the BaseDocument reference even though the docs say I can pass null
      please help.
      > _
      > static void GetWeightInfo(CAWeightTag *wtag) {
      >      if(LONG n = wtag->GetJointCount() ) {
      >           GePrint("weight joint count " + LongToString(n) );
      >           for(LONG i=0; i<n; i++) {
      >                if(BaseObject *jointRef = wtag->GetJoint(i, NULL ) ) {
      >                     GePrint(jointRef->GetName());
      >                if(LONG nw = wtag->GetWeightCount(i) ) {
      >                     GePrint(String("joint ") + LongToString(i) + String(" weight count ") + LongToString(nw) );
      > _
        On 28/09/2007 at 09:18, xxxxxxxx wrote:
        Matthias, anyone? where are you? I need your help with this 😞
          On 28/09/2007 at 09:25, xxxxxxxx wrote:
          you can pass NULL for example when the joint is not attached to a document. However, you should, if you can always pass a Document I highly assume.
            On 01/10/2007 at 18:45, xxxxxxxx wrote:
            resolved
            I was calling doc->Polygonize();
            which changes changes to the joints as well.
