    Store data in ASCII file... is possible?
    9 Posts 0 Posters 1.1k Views
      On 13/09/2007 at 14:58, xxxxxxxx wrote:
      Cinema 4D Version:   9.5
      Hello to everybody.
      I'm searching for a solution... a simple thing for you but not for me... by the way... I run an animation in C4D and I would like to store data produced by the COFFEE_Script attached  (data visible in the c4Dconsole).
      I would like to store them in a unique list and save this "data_list" as a file ascii in a specifiable position in HardDisk.
      Pratically i need to play animation and store all the running data visible by "println(MatriceTotale);" to an unique ascii data list"
      How can I do?
      The script:
      Create a cube in c4d... add this coffee script... animate the cube rotation... look at c4d console... i need to store these data...
      main(doc,op)
      var obj = doc->FindObject("Cube");
      var matrix = obj->GetMg();
      var globalRot = matrix->GetHPB();
      var stringa = stradd("x ",tostring(globalRot)," items.");
      // Rotazione HP
      var posizione = 3;
      var lunghezza = 8;
      // Rotazione HB
      var posizione1 = 12;
      var lunghezza1 = 8;
      var MatriceTotale = stradd("H", strmid(stringa,posizione,lunghezza), " P",strmid(stringa,posizione1,lunghezza1));
      Thanks in advance
        On 15/09/2007 at 14:13, xxxxxxxx wrote:
        Nothig is going the way I hoped...
        Please... need SOME HELP!
        It isn't a simple stupid test!
        There isn't a really easy way to explain how much important should be this help..
        Is it at least possible to do it??
        Some "Guru meditation" is needed.. 😉
        Thx
          On 16/09/2007 at 06:04, xxxxxxxx wrote:
          hi buzz,
          for that kind of stuff I use this set-up.
          It allows you to append parameters to a text-file per frame.
          hope this helps, frank.
            On 17/09/2007 at 01:55, xxxxxxxx wrote:
            Loading and saving files from within COFFEE expressions is forbidden. You have to write a script or try the setup Fank has posted, although it is not recommended to write or load files from within XPresso expressions.
              On 17/09/2007 at 12:38, xxxxxxxx wrote:
              Hi FrankBerg-Matthias,
              Tnx for tips 😉 setup posted seem to work wery well.. is very interesting this solution..   now I fell optimistic really.. many thanks 🙂
              This evening I turn my attention to a little LAST problem..  data stored aren't separated by "carriage return" so stored code look like a single data_block! 😞
              Some possible solutions?
              Best regards
              Chris
                On 17/09/2007 at 14:58, xxxxxxxx wrote:
                No sooner said than done.. really easy..
                Thanks for everything  🙂
                cheers
                Chris
                  On 24/04/2009 at 07:31, xxxxxxxx wrote:
                  How did you solve that problem with the single block versus single lines or a delimiter? I have the same problem now...
                  Rainer
                    On 24/04/2009 at 07:42, xxxxxxxx wrote:
                    Quote: _although it is not recommended to write or load files from within XPresso expressions.
                    _
                    this script was written in a time where I just started to write scripts so I forgive myself 😄
                      On 24/04/2009 at 08:55, xxxxxxxx wrote:
                      Lemo: Take a look at the sixth post:
                      http://py4d.xpresso24.com/wordpress/sdk/?wpforumaction=viewtopic&t;=34.0#4
