    Setting ID_BASEOBJECT_COLOR?
    SDK Help
    0
    • H
      On 10/09/2007 at 15:42, xxxxxxxx wrote:
      Cinema 4D Version:   10.111
      I want to color a null object and a spline that the user links into my expression. I tried like this (for the null object) :
      Vector Target_Color(1,1,0);
      Real Target_Radius = 25.0;
      BaseObject     *SC_TargetObj = tag->GetData().GetObjectLink(TARGET_OBJ, doc);
      SC_TargetObj->GetDataInstance()->SetLong(NULLOBJECT_DISPLAY, NULLOBJECT_DISPLAY_CIRCLE);
      SC_TargetObj->GetDataInstance()->SetReal(NULLOBJECT_RADIUS, Target_Radius);
      SC_TargetObj->GetDataInstance()->SetLong(ID_BASEOBJECT_USECOLOR, ID_BASEOBJECT_USECOLOR_ALWAYS);
      SC_TargetObj->GetDataInstance()->SetVector(ID_BASEOBJECT_COLOR, Target_Color);
      Setting NULLOBJECT_DISPLAY and NULLOBJECT_RADIUS works fine. The null object gets a cirle with the appropriate radius. But with ID_BASEOBJECT_USECOLOR and ID_BASEOBJECT_COLOR, nothing happens. No error message, but also no color.
      What's my mistake? Thanks for any help.
      Greetings,
      Jack
      • H
        On 11/09/2007 at 06:01, xxxxxxxx wrote:
        Is this the right way to put data into ID_BASEOBJECT_COLOR, anyway? How would you do this? Is there any example code in one of the example plugins?
        Regards,
        Jack
        • H
          On 11/09/2007 at 08:17, xxxxxxxx wrote:
          Try this instead for the last two values:
          SC_TargetObj->SetParameter(DescID(ID_BASEOBJECT_USECOLOR),GeData(ID_BASEOBJECT_USECOLOR_ALWAYS),0L);
          SC_TargetObj->SetParameter(DescID(ID_BASEOBJECT_COLOR),GeData(Target_Color),0L);
          • H
            On 11/09/2007 at 10:25, xxxxxxxx wrote:
            And that's totally correct.
            Thanks again for a very helpful post!
            Greetings,
            Jack
