    find all cameras in a scene ?
    7 Posts 0 Posters 604 Views
      On 05/08/2007 at 04:26, xxxxxxxx wrote:
      Cinema 4D Version:
      ---------I need to find all cameras in a scene ? how can I to do?
        On 05/08/2007 at 20:29, xxxxxxxx wrote:
        Hi ...
        Will it do my friend?
        void GetAllCameras(AtomArray *oCams,BaseObject *oCam)
             if(oCam)
                  if(oCam->GetType()==Ocamera)
                       oCams->Append(oCam);
        if(oCam->GetDown())
                       GetAllCameras(oCams,oCam->GetDown());
                  if(oCam->GetNext())
                       GetAllCameras(oCams,oCam->GetNext());
        LONG GetAllCameras(AtomArray *oCams)
             if(!oCams) return 0;
        BaseDocument *doc=GetActiveDocument();
             BaseObject *obj=doc->GetFirstObject();
             if(obj)
                  GetAllCameras(oCams,obj);
        return oCams->GetCount();
        You need to call the second function and then all the cameras will be in the AtomArray parameter you passed ...
        If you just want the count only ... you don't need that parameter ...
        For example ... you are using a command plugin and you got a button ... Then your command function will be ... like below ...
        Bool dlgYourPlugin::Command(LONG id,const BaseContainer &msg;)
             switch(id)
             case BTN_DISPLAY_CAMERAS:
                       LONG i;
                       AtomArray *oCameras=AtomArray::Alloc();
                       LONG lCamCnt=GetAllCameras(oCameras);
                       for(i=0;i<lCamCnt;i++)
                            BaseObject *obj=(BaseObject * )oCameras->GetIndex(i);
                            MessageDialog(obj->GetName());
                       AtomArray::Free(oCameras);
                  break;
        Wishing it can help you in a way ...
        Zaw Min Tun
          On 05/08/2007 at 22:30, xxxxxxxx wrote:
          hi, Zaw Min Tun
          thank you for your help?
            On 06/08/2007 at 03:07, xxxxxxxx wrote:
            I was added to two camera of target; but the return result is 0;  🙂
              On 06/08/2007 at 18:57, xxxxxxxx wrote:
              Hi ...
              I also tested before I post ... 🙂 ... and it worked ...
              So pls ... be sure to allocate the AtomArray before you pass to the LONG GetAllCameras(AtomArray *oCams) function ...
              AtomArray *varX=AtomArray::Alloc();
              LONG l=GetAllCameras(varX);
              MessageDialog(LongToString(l)+ " cameras!");
              It'll be more helpful if you can show me your code lines?
              Regards ...
              Zaw Min Tun
                On 06/08/2007 at 22:41, xxxxxxxx wrote:
                static void GetCameraSnapshoot( void );
                void LauntchWindow()
                 Bool bSingleModul = FALSE;
                 LONG OldProc = 0;
                 BaseObject* null = doc->GetActiveObject();
                 if (!null)
                  null = doc->GetFirstObject();
                   if (!null)
                   return ;
                 BaseTrack *track = null->GetTrack(Spla);
                 if (!track )
                  //is picture
                  nTypeObj = 0;
                 else
                  //is animal
                  nTypeObj = 1;
                 for ( LONG num = 0 ; num< 4; num++ )
                  //set view to active
                  SetActiveViewFromNum(num);
                  LONG proc = doc->GetBaseDraw( num )->GetProjection();
                  if ( OldProc == proc )
                   bSingleModul = TRUE;
                   break;
                  switch(proc )
                  case Pperspective:
                    if ( nTypeObj == 0)
                     Snapshoot("0_perspective"); //perspective is snapshoot name
                    else
                     Snapshoot("1_perspective"); //perspective is snapshoot name
                    break;
                  case Ptop:
                    if ( nTypeObj == 0)
                     Snapshoot("0_top");        //top is snapshoot name
                    else
                     Snapshoot("1_top");        //top is snapshoot name
                    break;
                  case Pright:
                    if ( nTypeObj == 0)
                     Snapshoot("0_right");
                    else
                     Snapshoot("1_right");
                   break;
                  case Pfront:
                    if ( nTypeObj == 0)
                     Snapshoot("0_front");
                    else
                     Snapshoot("1_front");
                    break;
                  OldProc = proc;
                 //is single view modul
                 if ( bSingleModul == TRUE )
                  BaseDraw *bd = doc->GetActiveBaseDraw();
                   switch( num )
                   case 0:
                     GeData da(BASEDRAW_PROJECTION_PERSPECTIVE);
                     bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL);
                     DrawViews(DA_ONLY_ACTIVE_VIEW);
                     //get snapshoot
                     if ( nTypeObj == 0)
                     else
                     break;
                   case 1:
                     GeData da(BASEDRAW_PROJECTION_TOP);
                     //get snapshoot
                     if ( nTypeObj == 0)
                     else
                     break;
                   case 2:
                     GeData da(BASEDRAW_PROJECTION_RIGHT);
                     //get snapshoot
                     if ( nTypeObj == 0)
                     else
                     break;
                   case 3:
                     GeData da(BASEDRAW_PROJECTION_FRONT);
                     //get snapshoot
                     if ( nTypeObj == 0)
                     else
                     break;
                   }//end switch
                }//end for
                  //reset to PERSPECTIVE
                  EventAdd();
                 GetCameraSnapshoot();
                void Snapshoot( char FileName[] )
                 if (!doc) return;
                 String sFileName = String( FileName ) + String(".jpg");
                    if (!null)
                  if (!null)
                   return;  //have't object
                 BaseContainer rdata = doc->GetActiveRenderData()->GetData();
                 //set to render as editor
                 rdata.SetBool(RDATA_RENDERASEDITOR, TRUE);
                 char* szPath = bNew CHAR[512];
                 GetShadeImageDir( szPath );
                 //MessageDialog(szPath);
                    //char * szPath = "C:\\Documents and Settings\\Administrator\\Turbo Squid Tentacles\\Uploaded\\Shade";
                 String sPath = String( szPath );
                  bDelete(szPath);
                 Filename renderpath = Filename( sPath ); // for instance
                 rdata.SetFilename(RDATA_PATH, renderpath);
                 //BaseBitmap* bmp = AllocBaseBitmap();
                 BaseBitmap* bmp = BaseBitmap::Alloc();
                 BaseBitmap* desbmp =  BaseBitmap::Alloc();
                 bmp->Init(rdata.GetLong(RDATA_XRES),
                    rdata.GetLong(RDATA_YRES));
                 desbmp->Init(rdata.GetLong(RDATA_XRES),
                 RenderDocument(doc, rdata, NULL, NULL, bmp, TRUE , NULL);
                 String sFullPath = sPath + "\" + sFileName;
                    //MessageDialog(sFullPath);
                 bmp->Save( Filename(sFullPath), FILTER_JPG, NULL, SAVEBIT_32b*tchANNELS);
                 BaseBitmap::Free( bmp );
                    BaseBitmap::Free( desbmp );
                static void SetActiveViewFromNum( LONG iNUM = 0 )
                 LONG lngIndex = 0;
                 lngIndex = iNUM;
                 switch( lngIndex )
                 case 0:
                   //BaseDraw *bd = doc->GetBaseDraw( 0);
                   //bd->SetBit( BIT_ACTIVE );
                   //bd->SetBit( BIT_DOCUMENT_CHECKREWIND );
                   //SendCoreMessage(EVMSG_ACTIVEVIEWCHANGED);
                   //EventAdd(EVMSG_ACTIVEVIEWCHANGED);
                       break;
                 case 1:
                   //BaseDraw *bd = doc->GetBaseDraw( 1 );
                  break;
                 case 2:
                   //BaseDraw *bd = doc->GetBaseDraw( 2);
                  break;
                 case 3:
                   //BaseDraw *bd = doc->GetBaseDraw( 3);
                  break;
                 EventAdd();
                     if(oCam)
                          if(oCam->GetDown())
                          if(oCam->GetNext())
                     if(!oCams)
                   //MessageDialog("Alloc AtomArray Fail that Can't get Camera ");
                   return 0;
                     if(obj)
                 LONG nCount = 0;
                 LONG nIndex[256] ={0};
                 AtomArray *oCameras = AtomArray::Alloc();
                 if ( !oCameras )
                  return ;
                    LONG lCamCnt = GetAllCameras(oCameras);
                 //MessageDialog( LongToString(lCamCnt) );
                    for(LONG i = 0;i < lCamCnt; i++)
                  if ( !obj) break;
                  String camname = obj->GetName();
                  LONG iLen = camname.GetCStringLen(St8bit)+1;
                  char* pName = bNew CHAR[iLen];
                  camname.GetCString( pName,iLen);
                  BaseObject * oldcam = doc->GetRenderBaseDraw()->GetSceneCamera( doc );
                  doc->GetRenderBaseDraw()->SetSceneCamera( obj );
                  Snapshoot( pName ); //perspective is snapshoot name
                  bDelete(pName);
                 AtomArray::Free(oCameras) ;
                 return ;
                this is my some codes: to get snapshoot (viewport and cameras) when the plugin be clicked and launch my operation windonws
                     the oCamera is NULL  when testing.  it was alloc failed
