    COFFEE does not recognize my element id
    8 Posts 0 Posters 839 Views
      On 28/07/2007 at 12:56, xxxxxxxx wrote:
      Cinema 4D Version:   R10
      Language(s) :   C.O.F.F.E.E  ;  C++  ;
      I have a string element in my SDK ObjectData plugin which I set with:
      data->SetString(AIMAP_STRING, "string data");
      but my coffee script does not recognize AIMAP_STRING:
      var str = obj#AIMAP_STRING;
      Is it possible to access this element with coffee?
      what do I need to do?
      thanks
        On 28/07/2007 at 14:33, xxxxxxxx wrote:
        Maybe try:
        var data = obj->GetData();
        var str = data->GetString(AIMAP_STRING); //(or maybe obj#AIMAP_STRING).
        I don't use COFFEE often enough to give a definitive answer on that part.
          On 28/07/2007 at 15:07, xxxxxxxx wrote:
          this should work.
          main(doc, op)
          doc = GetActiveDocument();
          op = doc->FindObject("MyObject");
          var str = op#AIMAP_STRING;
          println(str);
          hope I did not make a typo!
          frank
            On 28/07/2007 at 19:30, xxxxxxxx wrote:
            no luck both cause an exception.
            on this code as early as var data = cobj->GetData();
            try{
                      if(data) {
                           println("data ok");
                      if(str) {
                           file->WriteString(str);
                      } else {
                           println("empty string");
                      println("aimap data found");
                 catch(ExLastException){
                      println("aimap data not found");
              On 29/07/2007 at 10:07, xxxxxxxx wrote:
              This worked well 🙂
              var AIMAP_STRING = 10001; // container id in SDK
              var bc = cobj->GetContainer();
              var str = bc->GetData(AIMAP_STRING);
                On 29/07/2007 at 11:48, xxxxxxxx wrote:
                I think the problem is that your plugin ids are private - not general resources from c4d_symbols.h - which is how it's suppose to be. But that means that a COFFEE script won't have any idea what your plugin id enums are. So you'll probably have to do what you did or #include the resource header in the COFFEE script.
                  On 30/07/2007 at 05:12, xxxxxxxx wrote:
                  It seems there is a problem with the COFFEE symbol cache. What happens if you delete the "coffeesymbolchache" from the prefs folder? It should read your custom ID names then.
                    On 31/07/2007 at 09:02, xxxxxxxx wrote:
                    thanks so much both solutions worked, just that the header file solution needs modification e.g remove C++ compiler directives which coffee does not understand.
                    but the real solution was to clear the coffeesymbolchache. 🙂
                    coffeesymbolchache does not seem to be present on R9 so in that case the header should work.
