    change activebaseview and redrawer
    8 Posts 0 Posters 750 Views
      On 26/07/2007 at 21:13, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :   C.O.F.F.E.E  ;  C++  ;  XPRESSO  ;
      I want to change the activebaseview from top view to right view using doc->getbaseview(2) in the C++ code.
      how can I to do?
        On 27/07/2007 at 01:32, xxxxxxxx wrote:
        You can change the BaseDraw like this:
        BaseDraw *bd = doc->GetActiveBaseDraw();
        GeData d(BASEDRAW_PROJECTION_TOP);
        bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),d,NULL);
        This changes the active view to a top view. Look for "dbasedraw.h" file for IDs.
          On 29/07/2007 at 16:31, xxxxxxxx wrote:
          thank you very much
            On 29/07/2007 at 17:23, xxxxxxxx wrote:
            but the result is not I need for meaning, I would like the framework with cursor  from top view plance  to right view plance.  how Can I to Do?
              On 29/07/2007 at 21:51, xxxxxxxx wrote:
              You want to set the active view (as in the way you click the cursor in it to make it active) from top to right, you mean?
              I can't think of a way offhand. Since BaseDraw is derived from BaseList2D, it may be possible using SetBit() or ChangeNBit() but that's a guess.
                On 30/07/2007 at 00:04, xxxxxxxx wrote:
                Yes, I want to set the active view (as in the way you click the cursor in it to make it active) from top to right.
                  On 30/07/2007 at 18:39, xxxxxxxx wrote:
                  anyone can help for me?
                    On 31/07/2007 at 00:27, xxxxxxxx wrote:
                    I am not aware of any way to set the active view. In any case I asked the developers if there might be a way.
