    Instances dropped on Document::Polygonize
    6 Posts 0 Posters 653 Views
      On 26/07/2007 at 03:12, xxxxxxxx wrote:
      Cinema 4D Version:   10.1
      Hello, I am working on an exporter for C4D.
      I need to export instances, since our format is intended for real-time purposes, I let C4D polygonize object through the use of BaseDocument::Polygonize().
      The problem, is that Oinstances seems to be dropped by this function.
      Is there any way to recover Instances, or to do a stable match of the hiearchy between the original document, and the polygonized one ?
      Thanks 🙂
        On 26/07/2007 at 05:55, xxxxxxxx wrote:
        Maybe it's better to get your polygon objects on a per object basis. You can do this with GetDeformCache() and GetCache(). Here is a helper function to get the deformed polygon object of a selected object (it's from the upcoming SDK docu update).
        static void DoRecursion(BaseObject *op)
             BaseObject *tp = op->GetDeformCache();
             if (tp)
                  DoRecursion(tp);
             else
                  tp = op->GetCache(NULL);
                  if (tp)
                       DoRecursion(tp);
                  else
                       if (!op->GetBit(BIT_CONTROLOBJECT))
                            if (op->IsInstanceOf(Opolygon))
                                 // HERE IS THE DEFORMED POLYGON OBJECT
             for (tp = op->GetDown(); tp; tp=tp->GetNext())
                  DoRecursion(tp);
          On 26/07/2007 at 06:00, xxxxxxxx wrote:
          Ok !!! I will try this immediately
          Thanks 🙂
            On 27/07/2007 at 02:24, xxxxxxxx wrote:
            Arghhh, hell is in details 😄
            It seems that the texture tag is "lost" when processing a the last "op" level.
            One of the situation where the problem arises:
            - Make a landscape
            - Texture it basically (UVW mapping)
            - So that the object has only: a Texture Tag, and a Phong Tag
            When processing, the Texture Tag has gone (but it seems i have the UVW Tag).
            When using Polygonize(), i used to got everybody (TextureTag, UVWTag, PhongTag).
            I suppose that the TextureTag is on the previous recusion, i will dig onto this.
            But i will take any hints 🙂
              On 27/07/2007 at 02:27, xxxxxxxx wrote:
              BTW, i moved processing of sub objects to just after the polyobject generation.
              (i have a general hiearchy tracking outside of the equivalent of this recursive routine)
                On 07/08/2007 at 08:40, xxxxxxxx wrote:
                arghh, I hit another wall, so I have ended with a temporary solution involving just this (taken from Document::Polygonize() routine) :
                BaseObject *PolygonizeBaseObject( BaseObject *Src )
                BaseContainer Ctr;
                ModelingCommandData CData;
                CData.doc = Src->GetDocument();
                CData.bc = &Ctr;
                Ctr.SetBool(MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION,TRUE);
                CData.op = Src;
                if( !SendModelingCommand( MCOMMAND_CURRENTSTATETOOBJECT, CData ) || !CData.result )
                return NULL;
                BaseObject *CollapsedObject = (BaseObject* )CData.result->GetIndex(0);
                AtomArray::Free( CData.result );
                return CollapsedObject;
                So I just collapse a hierarchy branch with this call:
                AutoFree<BaseObject> PolyObject = PolygonizeBaseObject( Object );
                if( PolyObject )
                    MyObjectProcessor( PolyObject.... );
                I just wanted to know if the sequence above would disrupt or leak C4D ressources.
