    How to get target object in camera
    4 Posts 0 Posters 467 Views
      On 22/07/2007 at 01:00, xxxxxxxx wrote:
      Cinema 4D Version:
      I can to add an new camera? but can't get  target object to display in showmap()?  some anyone can help me? the code bellow :
      bool DoAddCamera()
        MessageDialog("AddCamera START!");
       BaseObject* null = doc->GetActiveObject();
          if (!null) return false;
       CameraObject* cam = (CameraObject* )BaseObject::Alloc(Ocamera);
       if ( !cam )
        MessageDialog("CameraObject Create Fail!");
        return false;
       doc->InsertObject(cam, NULL, NULL);
       Vector objvcr = null->GetMg().off;
       Vector camvcr;
       camvcr.x = objvcr.x - 500;
       camvcr.y = objvcr.y + 500;
       camvcr.z = objvcr.z - 500;
        cam->SetPos( camvcr );
        cam->SetRot(Vector(-0.8, -0.6, 0)); // Set rotation (radians, HPB)
      cam->SetZoom( 1.0 );
       cam->SetAperture( 36.0 );
       cam->SetFocus( 36.0 );
       cam->SetEditorMode( MODE_ON );
       AutoAlloc<BaseLink> link;
       link->SetLink( null );
       cam->SetParameter(DescID(TARGETEXPRESSIONTAG_LINK), GeData(link), NULL);
       EventAdd();
         // Active the camera
       BaseObject* oldcam = doc->GetActiveBaseDraw()->GetSceneCamera(doc);
       doc->GetActiveBaseDraw()->SetSceneCamera(cam);
       // Create some temporaries for the render
        BaseContainer rdata = cam->GetData();
          BaseBitmap* bmp = BaseBitmap::Alloc();
           bmp->Init(400, 400);
          DrawViews(DA_FORCEFULLREDRAW);
         bmp->Save( GeGetStartupPath() + "test_camera.jpg", FILTER_JPG ,&rdata,  SAVEBIT_32b*tchANNELS);
         // Active the old camera
        doc->GetActiveBaseDraw()->SetSceneCamera(oldcam);
       ShowBitmap(bmp);
      BaseBitmap::Free( bmp );
       MessageDialog("AddCamera End!");
        On 22/07/2007 at 11:39, xxxxxxxx wrote:
        DrawViews() only causes a redraw in the View editor. It does not create a render nor does it create a bitmap. You need to do a render - ala RenderDocument(). And then you need to get at the render bitmap.
          On 22/07/2007 at 18:58, xxxxxxxx wrote:
          hi Robert,  thank you for your help. but how can I get the originality snapshoot from the editviewport and to save it as..
            On 31/07/2007 at 00:59, xxxxxxxx wrote:
            I have been solved the problem, it have to render. but set the Basecontain as editor. this code:
            void Snapshoot( char FileName[] )
             MessageDialog("Snapshoot START!");
             if (!doc) return;
                   //get active object
                if (!null)
              null = doc->GetFirstObject();
              if (!null)
               return;  //have't object
            //get render data where container value of RDATA_RENDERASEDITOR setting true that status is edit and get snapshoot , can't to render
             BaseContainer rdata = doc->GetActiveRenderData()->GetData();
             //set to render as editor , is control code, must to SET TRUE,
            // otherwise is render.
            rdata.SetBool(RDATA_RENDERASEDITOR, TRUE);
             // Set render settings
             rdata.SetFilename(RDATA_PATH, Filename(null->GetName()));
             //BaseBitmap* bmp = AllocBaseBitmap();
             BaseBitmap* desbmp =  BaseBitmap::Alloc();
             bmp->Init(rdata.GetLong(RDATA_XRES),
                rdata.GetLong(RDATA_YRES));
             desbmp->Init(rdata.GetLong(RDATA_XRES),
             RenderDocument(doc, rdata, NULL, NULL, bmp, TRUE , NULL);
             bmp->Save( GeGetStartupPath() + "test_modul2.jpg", FILTER_JPG, NULL, SAVEBIT_32b*tchANNELS);
             if ( bmp )
              bmp->ScaleBicubic( desbmp, 0,0, bmp->GetBw(), bmp->GetBh(), 0, 0, 400, 400);
            //ShowBitmap(bmp);
             if (bmp)
              bmp->ScaleBicubic( desbmp, 0, 0, bmp->GetBw(), bmp->GetBh(), 0, 0, 400, 400);
              desbmp->Save(GeGetStartupPath() + "test_modul3.jpg", FILTER_JPG, NULL, SAVEBIT_32b*tchANNELS);
                BaseBitmap::Free( desbmp );
               MessageDialog("end !");
