    Render Data Container Names
    3 Posts 0 Posters 258 Views
      On 15/07/2007 at 18:49, xxxxxxxx wrote:
      Cinema 4D Version:   10.111
      Platform:      Mac OSX  ;
      I'm trying to create a plug-in that saves out render data to an external file. I can do this by querying the base container line by line for every value there (for example with RDATA_FRAMERATE, RDATA_ANTIALIASING, etc.) and storing those values in variables. This is pretty time consuming and not very flexible.
      The other way I can do this is to get the data by iterating through the Index Ids, which works, as well, but I can't figure out how to actually get an associated container name for those IDs (which I would really like to have). For example, I can get a value of 320 for ID 5008, which corresponds to output resolution width, but, I'd like it to return "RDATA_XPIX."
      Is there any way to do this?
        On 16/07/2007 at 01:11, xxxxxxxx wrote:
        iterating through the IDs is not save, they might change with future versions of Cinema.
          On 16/07/2007 at 08:23, xxxxxxxx wrote:
          So, you think it is better to hard code this line by line? This is definitely doable, but leaves me in the dark a little bit since I don't know what video post plug-ins a user might have. (For instance, VRay is supposed to be released soon)
          I'd still like to know if there is a way to return the name of the container. It will make it a lot easier to code this, rather than having to dig through the SDK to find what I'm looking for.
