    RangeMapper function in C.O.F.F.E.E.?
    5 Posts 0 Posters 504 Views
      On 13/07/2007 at 16:45, xxxxxxxx wrote:
      Cinema 4D Version:   10.111
      I wondered if there is some function in C.O.F.F.E.E. that works like the RangeMapper node in XPresso. Especially I am looking for a possibility to use a spline curve , just like in the node.
      Is there anything I could use?
      Best regards,
      Jack
        On 16/07/2007 at 01:08, xxxxxxxx wrote:
        no, you have to write your own. you could use a dummy splineobject to read out interpolated inbetween points though. as long as you don't insert it into the document it will be invisible to the user.
          On 16/07/2007 at 02:03, xxxxxxxx wrote:
          Hi Matthias,
          I was hoping for an answer from you 😉
          Actually, I take the occasion as a good reason to get into C++
          And there I immediately get new problems with VisualC++ 2005 Express. Maybe you'll here from me some more times.
          Best regards from Braunschweig,
          Frank
            On 20/07/2007 at 07:14, xxxxxxxx wrote:
            Howdy,
            A range mapper is fairly easy to code:
            if((inMax-inMin) != 0)   //Check for division by 0
                   mix = (input-inMin)/(inMax-inMin);
            else
                  mix = 0;
            output = outMin + mix * (outMax-outMin);
            Adios,
            Cactus Dan
              On 23/07/2007 at 00:04, xxxxxxxx wrote:
              Hey Dan,
              yeah, without the spline function, it is quite easy. Thanks for the code! But since I want to use especially the spline of the Range Mapper node, I can't use it.
              Anyway I started learning C++ for CINEMA 4D SDK (learning by doing), so I will do everything different as I planned.
              Thanks for your help!
              Greetings,
              Frank
