    Worldspace to Screenspace conversion
    7 Posts 0 Posters 677 Views
      On 04/07/2007 at 05:21, xxxxxxxx wrote:
      Cinema 4D Version:   R10
      Platform:      Mac OSX  ;
      i'm looking for a way to convert world coordinates to screen coordinates in COFFEE. I know in cg-shader-language, I just have to multiply the local coordinates with the model-view-projection matrix.
      Can I access a similar matrix inside COFFEE? Or do I have to create it all by myself (based on camera position, rotation and focal length)?
      Or (even better) : is there a function, which does exactly that conversion?
      Best regards,
      sk.
        On 04/07/2007 at 07:40, xxxxxxxx wrote:
        Nope, there is no such function in COFFEE. In C++ however you have several functions to convert from/to world, camera and screen space.
          On 05/07/2007 at 04:54, xxxxxxxx wrote:
          I am quite sure that the source code for the function used internally by C4d to do world->screen projections is avilable somewhere in the C++ API docs. Using that as reference, implementing a corresponding function in COFFEE should not be that hard.
          If you can't find it, let me know and I'll look it up for you.
          /Filip
            On 05/07/2007 at 08:40, xxxxxxxx wrote:
            Totally forgot about this. It´s in the GetViewParameter description. At least that´s the only source I know.
              On 05/07/2007 at 08:49, xxxxxxxx wrote:
              Nice tip, but it seems like the BaseView-class, which implements the WS() method is proprietary or something. At least I found only the header-file in the SDK, not the source itself. If you find out more, please let me know.
              For this project a C++ plugin would only be the last resort, so I fear I have to create the matrix myself. I found a nice tutorial to calculate the projection matrix (http://www.codeguru.com/cpp/misc/misc/math/article.php/c10123\__3/), the rest should be relatively easy. But a built-in approach would be much more desirable, of course!
              sk.
                On 06/07/2007 at 12:53, xxxxxxxx wrote:
                As I said, it´s in the GetViewParameter description of the C++ SDK documentation!
                  On 06/07/2007 at 13:40, xxxxxxxx wrote:
                  Thank you, guys...
                  I simply overlooked that part. So after a good deal of tweaking, I've got a more or less working plugin. 🙂
                  I haven't found out, how to react to changes in the focal length, though... This negative-z value seems to be hard-coded to the standard-issue 36mm camera. But I guess that'll be not that much of a problem, and it's not that important anyway.
                  greets,
                  stefan
