    String arrays?
    3 Posts 0 Posters 298 Views
      On 19/06/2007 at 18:05, xxxxxxxx wrote:
      Cinema 4D Version:   R8.2-R10
      Maybe it's me, but my plugin is crashing whenever I try to use an array of strings:
      String* strings;
      strings = bNew String[count];
      *strings = String("xxx");
      ++strings;
      This seems to cause grief. I've double checked the code and it seems on the up-and-up as far as cheching and setting. Is it possibly a problem of initialization of the strings in the array?
      This is only a temporary array storing names before tag assignments are made using them. Any alternatives ideas if this doesn't pan out?
      Thanks!
        On 20/06/2007 at 08:25, xxxxxxxx wrote:
        you are defining an array, but the contents of it are undefined. try this.
        String* strings[count];
        for(int x=0; x<count; x++)
        = new String("xxx");
        String *stringRef = strings[0];
        ++ stringRef;
        remember to free the strings after.
          On 20/06/2007 at 08:43, xxxxxxxx wrote:
          Actually I think that the problem has been found. I remembered to free the strings - but too early, forgetting that the individual group references were into that array.
          Was trying to use a single array to cover all of the instances in the group tree and handling that got sticky. Instead, the code now does a prepass to count the number of strings needed for each group and allocates individual arrays per group. Each group frees its String array after processing. It now works as expected. 🙂
          Thanks!
