    ModellingCommand, container IDs?
    3 Posts 0 Posters 399 Views
      On 19/06/2007 at 14:07, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      Hello.
      I'm trying to call the EditSpline:project function using SendModellingCommand. To do this I need to set a LONG(
      MDATA_SPLINE_PROJECTMODE)
      in the basecontainer of the   ModelingCommandData. How can I figure out which values of MDATA_SPLINE_PROJECTMODE that correspond to which projection mode? The docs only say "see dialog", but I don't see how that helps me?
      /Filip
        On 19/06/2007 at 16:44, xxxxxxxx wrote:
        What it should say is "see dialog and then see resources". 🙂
        When there is a set of constant defines they will almost always be listed in either the _api class headers or in the res or modules folder in the Resource folder.
        In this instance, "Projection Mode" is found under the Project command (Structure->Edit Spline->Project).
        And the relevant file is:
        Resource:Modules:Modeling:Res:Description:toolsplineproject.h
        #ifndef _ToolSplineProject_H_
        #define _ToolSplineProject_H_
        enum
             MDATA_SPLINE_PROJECT_MODE                                        = 2022, // LONG
                  MDATA_SPLINE_PROJECT_MODE_VIEW        = 0,
                  MDATA_SPLINE_PROJECT_MODE_XY           = 1,
                  MDATA_SPLINE_PROJECT_MODE_ZY           = 2,
                  MDATA_SPLINE_PROJECT_MODE_XZ           = 3,
                  MDATA_SPLINE_PROJECT_MODE_X_AXIS       = 4,
                  MDATA_SPLINE_PROJECT_MODE_Y_AXIS       = 5,
                  MDATA_SPLINE_PROJECT_MODE_Z_AXIS       = 6,
                  MDATA_SPLINE_PROJECT_MODE_SPHERICAL    = 7,
        #endif // ToolSplineProject
          On 20/06/2007 at 01:02, xxxxxxxx wrote:
          That's exactly what I needed. Thanks a lot!
          /Filip
