    Save Project
    6 Posts 0 Posters 525 Views
      On 03/06/2007 at 18:59, xxxxxxxx wrote:
      Cinema 4D Version:   9.6+
      Language(s) :
      Hi all,
      How i can detect that a scene is saved in a project?
      I suppose that must be check in the NODEDATA::write.
      I need to copy all IES light files in the project folder when saved.
      Thanks in advance
      Renato
        On 04/06/2007 at 04:55, xxxxxxxx wrote:
        BaseDocument::GetDocumentPath() can be used to determine if the scene is/has been saved to disk. If not, the Filename is empty:
        if (!doc->GetDocumentPath().Content()) GePrint("Unsaved Document");
        Don't know if there is a means to determine if saved as a project into a folder. But the files should be local to the .c4d document if saved either way.
        Hth,
          On 04/06/2007 at 06:38, xxxxxxxx wrote:
          Thanks Robert,
          so i can put in write a copy for these files in the documentpath 🙂
          Renato
            On 04/06/2007 at 08:06, xxxxxxxx wrote:
            Hi All,
            this code seem to work.. except that the doc path is the older path and not the new path.
            How can i get the saved path?
            Filename docpath = hf->GetDocument()->GetDocumentPath();
            BaseContainer     *data = ((BaseObject* )node)->GetDataInstance();
            myIesFile = data->GetFilename(VRAYLIGHTTAG_IES_FILE);
            docpath = docpath + myIesFile.GetFile();
            GeFCopyFile(myIesFile,docpath,FALSE);
            data->SetFilename(VRAYLIGHTTAG_IES_FILE,docpath);
            cheers
            Renato
              On 04/06/2007 at 10:25, xxxxxxxx wrote:
              What do you mean by 'older path' and 'new path'? Are you trying to do this *while* saving the document? That's gonna be difficult as DocumentPath probably hasn't been updated yet - probably after the save is complete.
              The only other possibility is the MSG_DOCUMENTINFO sent when a document is loaded, saved. Check the docs for that one.
                On 04/06/2007 at 10:29, xxxxxxxx wrote:
                Thanks Robert,
                i'll do 🙂
                Renato
