    Working around missing QuickTime support?
    13 Posts 0 Posters 1.3k Views
      On 08/06/2007 at 00:51, xxxxxxxx wrote:
      Sorry, absolutely no clue. This is definetly not my metier. My very guess would have been Paintlib too, but I donΒ΄t have any experience with it.
      No help, but a sign of life at least! πŸ™‚
        On 10/06/2007 at 21:35, xxxxxxxx wrote:
        Unfortunately, Paintlib is a mess with missing source/header files and other problems.
        For PNG support, libpng is it. Wow! It loads PNGs (even with alpha channels) 5+ times faster than the QuickTime support used by Cinema 4D. I am converting all of my version support to use it instead.
        If anyone needs such support for 64-bit Windows (or generally in Cinema 4D), I'd be happy to forward my source.
          On 12/06/2007 at 07:34, xxxxxxxx wrote:
          thanks for the info. Glad you found something. πŸ™‚
            On 12/06/2007 at 11:07, xxxxxxxx wrote:
            One thing to note is that libpng doesn't currently come with VS2005, CodeWarrior, or Xcode projects. There is a VS2003 project, but I found it clumsy in conversion and built my own from the zlib static lib project used by the plugin.
            Even then, I had to fiddle with this project's build settings to remove 'unresolved external symbol' errors related to libpng during link with my plugin - about three hours of frustration before it started working. πŸ˜‰
            Still dealing with a similar situation in Xcode - unresolved external links which seem to be functions that aren't being included by any of the billion #defines. This will require some detective work. πŸ™‚
              On 28/11/2007 at 02:20, xxxxxxxx wrote:
              Quote: _If anyone needs such support for 64-bit Windows (or generally in Cinema 4D), I'd be happy to forward my source.
              _
              Hey Robert,
              this is exactly what i was looking for, since all 64-bit/vista users cant run my plugin anymore, it would be great if you could share that piece of code.
              thanks in advance!
                On 28/11/2007 at 13:03, xxxxxxxx wrote:
                Are you looking to use libpng for PNG image file support in these Windows versions?
                  On 28/11/2007 at 15:20, xxxxxxxx wrote:
                  yes, or eventually anything else that works πŸ™‚
                    On 28/11/2007 at 16:56, xxxxxxxx wrote:
                    You can download a zip containing the following from the link below:
                    - 64-bit Windows static libs built with VS2005
                    - Headers for zlib and libpng (libpng requires zlib for compression/decompression)
                    - Readme.txt to exemplify use of the PngLoad class
                    Of course, you can download the latest zlib and libpng if you need to build the static libs yourself. It is a bit tricky to set up the VS2005 project (as none accompanies these libs).
                    http://www.kuroyumes-developmentzone.com/_private_/libpng&src.zip;
                      On 29/11/2007 at 00:50, xxxxxxxx wrote:
                      thank you. but i cant download that file. also cant open your site.
                      can you please mail me the file?
                      yvescolle at hotmail dot com
                        On 29/11/2007 at 08:16, xxxxxxxx wrote:
                        Can you try the link again and let me know if it works? I just upgraded NAV and, brilliant, it didn't retain any of my previous settings. I can access everything, but can't test offsite. Working on getting the entire server back online. Hopefully the web server is accessible now.
                          On 29/11/2007 at 10:35, xxxxxxxx wrote:
                          its working now, thank you very much!!!
