    Description's elements.
    4 Posts 0 Posters 437 Views
      On 22/05/2007 at 08:16, xxxxxxxx wrote:
      Cinema 4D Version:   10
      how to enable/disable (i mean to put in inactive and than in active state) descriptions elements like SHADERLINK, REAL, etc.
        On 22/05/2007 at 11:31, xxxxxxxx wrote:
        I found the answere here
        but still don't know how to use it 😉
        i have sth like this:
        Bool test = GetDEnabling(node, DescID(MATERIAL_BUMP_MIPFALLOFF2), GeData("false"), 0, data);
        and SDK says:
        "Just read the passed t_data if the right id was provided, and return TRUE to enable the parameter or FALSE to disable it depending on the value."
        and my t_data is here GeData("false") and i doesn't work.
        I've tried everything.
          On 22/05/2007 at 11:39, xxxxxxxx wrote:
          GetDEnabling() allows you to change the state from editable to non-editable (greyed-out). This is a virtual method that you add to your data class (see NodeData in the docs) - you can't 'call' it as it is handled by Cinema 4D internally.
          Inside, you return TRUE (enable) or FALSE (disable) based upon the description element ID:
          / NodeData.GetDEnabling
          Bool IPPFigure::GetDEnabling(GeListNode* node, const DescID& id, GeData& t_data, LONG flags, const BaseContainer* itemdesc)
               if (!node)     return FALSE;
               switch (id[0].id)
                    // Quick BodyPart Traversal Buttons
                    case IPPFIGURE_BP_UP:
                         return (upBP_ID >= 0L);
                    case IPPFIGURE_BP_DOWN:
                         return (downBP_ID >= 0L);
                    case IPPFIGURE_BP_PREV:
                         return (prevBP_ID >= 0L);
                    case IPPFIGURE_BP_NEXT:
                         return (nextBP_ID >= 0L);
                    // Assorted
                    case IPPFIGURE_COPYMORPHS:
                         BaseContainer*     bc =     ((BaseTag* )node)->GetDataInstance();
                         if (!bc)                    return TRUE;
                         if (bc->GetBool(IPPFIGURE_CONFORMED))     return TRUE;
                         return FALSE;
                    case IPPFIGURE_BULGEFACTOR:
                         if (bc->GetBool(IPPFIGURE_BULGE))          return TRUE;
                         return FALSE;
                    case BODYPART_BULGEFACTOR:
                         if (bc->GetBool(BODYPART_BULGE))          return TRUE;
                         return FALSE;
                    case IPPFIGURE_POLYCOUNT:
                    case IPPFIGURE_UNDOS:
                         return FALSE;
                    default:
                         break;
               return SUPER::GetDEnabling(node, id, t_data, flags, itemdesc);
          You didn't try this? 😉
            On 22/05/2007 at 13:07, xxxxxxxx wrote:
            That was very helpfull. Thanks a lot.
