    GetBit(BIT_ARDATA) doesnt work?
    5 Posts 0 Posters 532 Views
      On 17/05/2007 at 12:27, xxxxxxxx wrote:
      Cinema 4D Version:   C10
      Hello, I'm new here. Is it ok if I'm bad in english?
      I just have a question:
      I'm using GetBit(BIT_ARDATA) to get the Active Render Data
      with
      doc->GetFirstRenderData->GetBit(BIT_ARDATA);
      but the result ist always 0. it doesn't matter if i select the first render data in menu or not. I've noticed it that it works only in Cinema version 9.6.
      Seems it is a bug? Or did I do something wrong?
      thanks very much!
        On 17/05/2007 at 13:51, xxxxxxxx wrote:
        COFFEE hasn't yet been updated for R10 - at least the lack of COFFEE docs for R10 suggests this.
        R10 has many changes that not even we C++ developers have control of yet. And there are changes that may have impact otherwise. For instance, BaseList2D::GetBit(BIT_OFOLD) and other manager fold bits no longer work in R10. These are now handled through GeListNode::GetNBit() (R10 ONLY!).
        So it is possible that you are experiencing something similar - but without an updated COFFEE for R10 it will be difficult if not impossible to work around.
          On 18/05/2007 at 03:08, xxxxxxxx wrote:
          this is a bug in the current cinema version
            On 23/05/2007 at 00:40, xxxxxxxx wrote:
            found out that there is a new symbol in Cinema4D R10. use BIT_ACTIVERENDERDATA instead of BIT_ARDATA.
              On 01/06/2007 at 11:33, xxxxxxxx wrote:
              thank you very much!!!
