    Getting data from SHADERLINK
    8 Posts 0 Posters 686 Views
      On 13/05/2007 at 14:10, xxxxxxxx wrote:
      Cinema 4D Version:   10
      i can't find any tutorials about introduction about writing sdk plugins, and i have (propably) realy basics problems.
      I created a simple SHADERLINK in gui,
      (like that: SHADERLINK MATERIAL_ALPHA_SHADER2 { } ), and i'm trying, and trying, and trying to read data and everything gone for nothing.
      example:
      BaseDocument *doc;
      BaseLink *tekstura;
      BaseList2D *bl;
      // in InitRender
      PluginShader *shader = NULL;
      tekstura = data->GetBaseLink(MATERIAL_ALPHA_SHADER2);
           if(tekstura!=NULL){
                bl = tekstura->ForceGetLink(); // when i trying to use tekstura- >GetLink(doc);, the methon returns null
                shader = bl->GetFirstShader(); // < --- here i always get null -- why??
                PluginShader *ge = (PluginShader * )bl; // < -- is this correct?
      // in CalcSurface
           if(tekstura!=NULL){
                shader = bl->GetFirstShader(); // always null
                Vector btm = ge->Sample((ChannelData * )vd); // always null
      GePrint("Name: "+ge- >GetName()); // functions works fine, that's why i thing that at least some of this code is correct 😉
      I would be very gratefull for any help, or pice of good code.
        On 19/05/2007 at 06:37, xxxxxxxx wrote:
        Can somebody help me?
        This is very important for me.
          On 21/05/2007 at 01:45, xxxxxxxx wrote:
          What are you trying to achieve, simply loading a shader in your own shader? Take a look at the Bitmapdistortion Shader in the SDK examples. It shows how to initialize and use a ShaderLink.
            On 21/05/2007 at 23:45, xxxxxxxx wrote:
            What I'm trying to achieve is to load a shader in SHADERLINK, and use it as a color of object or as a bump texture - it doesn't matter.
            Bitmapdistortion Shader inherit from ShaderData, my plugin inherts from MaterialData - that's why Bitmapdistortion Shader isn't very helpfull example.
            i found this
            but this is too all about ShaderData.
              On 22/05/2007 at 02:08, xxxxxxxx wrote:
              Here is a complete example for MaterialData plugin which loads a shader and uses it in CalcSurface
              // CINEMA 4D SDK                                           //
              // (c) 1989-2004 MAXON Computer GmbH, all rights reserved //
              // example for an easy implementation of a volume (surface) shader
              // It modifies the preview scenes and adds its own scene
              #include "c4d.h"
              #include "c4d_symbols.h"
              #include "msimplematerial.h"
              #define ID_SIMPLEMAT 1001164
              class SimpleMaterial : public MaterialData
                   INSTANCEOF(SimpleMaterial,MaterialData)
                   private:
                        PluginShader *shader;
                        virtual Bool Init          (GeListNode *node);
                        virtual     void CalcSurface               (PluginMaterial *mat, VolumeData *vd);
                        virtual     LONG InitRender(PluginMaterial *mat, InitRenderStruct *irs);
                        virtual void FreeRender(PluginMaterial* mat);
                        virtual Bool Message(GeListNode* node, LONG type, void* data);
                        static NodeData *Alloc(void) { return gNew SimpleMaterial; }
              Bool SimpleMaterial::Init(GeListNode *node)
                   shader = NULL;
                   BaseContainer *data=((PluginMaterial* )node)->GetDataInstance();
                   data->SetLink(SIMPLEMATERIAL_TEXTURE,NULL);
              LONG SimpleMaterial::InitRender(PluginMaterial *mat, InitRenderStruct *irs)
                   BaseContainer *data=mat->GetDataInstance();
                   shader = (PluginShader* )data->GetLink(SIMPLEMATERIAL_TEXTURE,irs->doc,Xbase);
                   if (shader)
                        return shader->InitRender(irs);
                   return LOAD_OK;
              void SimpleMaterial::FreeRender(PluginMaterial *mat)
                   if (shader)
                    shader->FreeRender();
                   shader=NULL;
              void SimpleMaterial::CalcSurface(PluginMaterial *mat, VolumeData *vd)
                   if(shader)
                        ChannelData cd;
                        cd.vd = vd;
                        cd.d = 0;
                        cd.n = vd->n;
                        cd.off = 0;
                        cd.p = vd->uvw;
                        cd.scale = 0;
                        cd.t = 0;
                        cd.texflag = TEX_TILE;
                        Vector col = shader->Sample(&cd;);
                        vd->col = col;
                        Multipass *buf = vd->multipass;
                        if (!buf) return;
                        // process multipass data
                        *buf->vp_mat_color = col;
                   else
                        vd->col = 1.0;
                        if (!buf) return;
                        *buf->vp_mat_color = 1.0;
              Bool SimpleMaterial::Message(GeListNode* node, LONG type, void* data)
                   BaseContainer *dat = ((PluginShader* )node)->GetDataInstance();
                   HandleInitialChannel(node,SIMPLEMATERIAL_TEXTURE,type,data);
                   HandleShaderMessage(node,(PluginShader* )dat->GetLink(SIMPLEMATERIAL_TEXTURE,node->GetDocument(),Xbase),type,data);
              Bool RegisterSimpleMaterial(void)
                   // decide by name if the plugin shall be registered - just for user convenience
                   String name=GeLoadString(IDS_SIMPLEMATERIAL); if (!name.Content()) return TRUE;
                   return RegisterMaterialPlugin(ID_SIMPLEMAT,name,0,SimpleMaterial::Alloc,"Msimplematerial",0);
              here the description resource
              CONTAINER Msimplematerial
                   NAME Msimplematerial;
                   INCLUDE Mpreview;
                   INCLUDE Mbase;
                   GROUP ID_MATERIALPROPERTIES
                        SHADERLINK SIMPLEMATERIAL_TEXTURE { }
              also take a look a look at the material examples in the sdk
                On 22/05/2007 at 02:44, xxxxxxxx wrote:
                Thank you for help. I was looking sth like this example.
                I have last question, only for sure.
                there is no difrents between this
                ChannelData cd;
                          cd.vd = vd;
                          cd.d = 0;
                          cd.n = vd->n;
                          cd.off = 0;
                          cd.p = vd->uvw;
                          cd.scale = 0;
                          cd.t = 0;
                and this:
                ChannelData *cd = new ChannelData(vd);
                          Vector col = shader->Sample(cd);
                right?
                  On 22/05/2007 at 02:50, xxxxxxxx wrote:
                  Quote: there is no difrents between this
                  > ChannelData cd;
                  >           cd.vd = vd;
                  >           cd.d = 0;
                  >           cd.n = vd->n;
                  >           cd.off = 0;
                  >           cd.p = vd->uvw;
                  >           cd.scale = 0;
                  >           cd.t = 0;
                  > and this:
                  > right?
                  no, but still you have to fill the ChanndelData first, like cd->vd = vd etc. also don't forget to free your ChannelData with delete after using it.
                    On 22/05/2007 at 03:16, xxxxxxxx wrote:
                    Thanks, i'm appreciate for your help.
