    AnimateObject / GetMg
    11 Posts 0 Posters 1.2k Views
      On 11/05/2007 at 20:22, xxxxxxxx wrote:
      Cinema 4D Version:   9.6+
      Hi all,
      i'm inside VP_INNER.
      Good place to play.. 🙂
      I need to calculate the true motion blur, this mean that the mblur take account of trajectories.
      So i can't use motion_delta, because i can reconstruct only 2 points of my motion.
      So i used AnimateObject.
      All is ok.. but when i use a virtual object like a sphere, the sphere->GetMg() don't change with the AnimateObject call.
      Because: GetMg()
      "The will only work if the object is attached to a document. Virtual objects in caches and deform caches are not attached to a document, so this function cannot be used for those objects."
      When i make it editable, all ok 🙂
      I'm getting the
      BaseObject *myObj = Vd->GetObj(n)->link;
      BaseDocument *myDoc = myObj->GetDocument();
      myDoc->AnimateObject(myObj, myTime, flag);
      Matrix m = myDoc->GetMg(); <-- this is my prob.
      any suggestion to get the matrix from here?
      thanks in advance
      Renato
        On 13/05/2007 at 10:10, xxxxxxxx wrote:
        Hi all
        can i know how these function work from BaseObjects?
        These functions seem related to virtual objects.
        void SetOrigin(BaseObject* origin);
        BaseObject* GetOrigin(Bool safe);
        BaseObject* GetTopOrigin(Bool parent, Bool safe);
        BaseObject* GetEditObject(BaseObject** psds, LONG state);
        Renato
          On 14/05/2007 at 03:13, xxxxxxxx wrote:
          Do you use AnimateObject within VP_INNER? I am not sure this is safe to do, at least not with the original document.
            On 14/05/2007 at 03:14, xxxxxxxx wrote:
            The SetOrigin, GetOrign, GetTopOrigin and GetEditObject functions are private and shouldn't be used by plugin developers.
              On 14/05/2007 at 04:15, xxxxxxxx wrote:
              Ok Matthias.
              What's way i need to get to calculate the trajectory of an RayObject if i can't get the real object?
              Renato
                On 14/05/2007 at 06:01, xxxxxxxx wrote:
                I don't think this is possible with RayObjects. You probably have to do this outside of the videopost. I know that Final Render calculates some sort of prepass but I don't know if they do this within a videopost since I don't have access to Final render.
                  On 14/05/2007 at 07:46, xxxxxxxx wrote:
                  Ok, i'll think another way to do it.
                  but i've tried the GetTopOrigin(Bool parent, Bool safe);
                  and seem to return the real BaseObject that generated the Virtual objecs. Why this function must not be to used?
                  Renato
                    On 15/05/2007 at 01:51, xxxxxxxx wrote:
                    I talked with the developers about the motion blur issue and the way to get your subsamples is to clone the document and manually step through it.
                      On 15/05/2007 at 01:56, xxxxxxxx wrote:
                      Hi Matthias.
                      About getting the BaseObject from rayobject?
                      If it's a virtual objects i can't get real reference to it.
                      Renato
                        On 15/05/2007 at 02:00, xxxxxxxx wrote:
                        no, you have to clone your complete document and work with the clone. there you have access to the real objects. step through the document with SetTime and AnimateDocument.
                          On 15/05/2007 at 02:55, xxxxxxxx wrote:
                          Ok Matthias,
                          but.. when i'll be in VP_INNER and i'm exporting all objects.. it's when i must pass the subsampled matrix for each object.
                          So, how i can know from a Rayobject what's the link if this rayobject is a Virtual Object generated?
                          Renato
