    What does the _bc stands for?
    5 Posts 0 Posters 403 Views
      On 17/04/2007 at 07:54, xxxxxxxx wrote:
      Cinema 4D Version:   10.x
      Platform:      Mac OSX  ;
      I usually use a generic framework to code my plug-ins. In them, I use, for example, the line:
      PluginDialog::SetContainer(_bc) { bc = _bc->GetClone(); }
      Why does the bc has an underscore behind it? What does the underscore stands for? I mean, what is the difference between bc and _bc ?
      Thank you in advance for any reply.
      Rui Batista
        On 18/04/2007 at 03:14, xxxxxxxx wrote:
        Hello Rui,
        AFAIK, names that begins with an underscore are reserved for libraries like stl or for compilers it self.
        So actually it is better to use bc_ instate of _bc.
        But in some cases underscore are used to do something like this.
        class SomeClass
            SomeClass(BaseContainer &_bc) : bc(_bc) {}
            BaseContainer bc;
        // I would prefer to use something like this
        class SomeClass
            SomeClass(BaseContainer &bc;) : m_bc(bc) {}
            BaseContainer m_bc;
        If this is not answer to you question then I have understand you question wrong. 🙂
        Remo
          On 18/04/2007 at 03:25, xxxxxxxx wrote:
          So, the underscore is just another character to make the variable _bc different from bc?
          The underscore has no special function like, for example the ! or & characters?
          That means that I could very well write:
          PluginDialog::SetContainer(other_bc) { bc = other_bc->GetClone(); }
          instead of:
          is it?
            On 18/04/2007 at 03:49, xxxxxxxx wrote:
            Yep, it´s just a variable name, like you are Rui and I am Samir 🙂
              On 18/04/2007 at 03:57, xxxxxxxx wrote:
              Thank you both 🙂
              That really helped ALOT!!!
