    Open File with custom filetypes?
    7 Posts 0 Posters 622 Views
      On 11/03/2007 at 21:30, xxxxxxxx wrote:
      Cinema 4D Version:   10
      I am most likely being dense, but is there a way of specifying a custom filetype in the Open File dialog?
        On 12/03/2007 at 02:52, xxxxxxxx wrote:
        Can you give a bit more detailed explaination of what you are trying to do please?
          On 12/03/2007 at 10:54, xxxxxxxx wrote:
          Sure, and thank you for the quick response.
          My plug-in needs to load an external file that is not one of the standard file types (image/coffee/scene) included in the API's Open File dialog. I am hoping there is a simple way to modify the Open dialog's file type filter to at least include my file type. Even better if I can completely specify a filter list of my own. Right now, I am using a Filename entry in a BaseContainer.
          The All Files (*.* ) filter will certinly work but a custom filter is nicer from a user perspective.
            On 15/03/2007 at 04:00, xxxxxxxx wrote:
            afaik you can't specify a filter for your file extensions. i will ask the developers though.
              On 15/03/2007 at 10:45, xxxxxxxx wrote:
              OK, thanks. Please do let me know. By the way, you folks have terrific support!
                On 16/03/2007 at 13:58, xxxxxxxx wrote:
                Got the confirmation from the developers, it's not possible at the moment to create custom extension filters.
                  On 18/03/2007 at 19:21, xxxxxxxx wrote:
                  OK, thank you for checking.
