    XCode version slower?
    32 Posts 0 Posters 17.5k Views
      On 16/02/2007 at 05:50, xxxxxxxx wrote:
      But the documentation says, it´s just like "fastest" however trying to create as small as possible output. :-? I don´t know, it all seems strange in this compiler. Anyway, I will also try a compile with "fastest" only and see if this makes any difference.
      I don´t think they mean smallest as in very small code, but I think simply smaller than the fastest...hopefully 🙂
        On 16/02/2007 at 06:19, xxxxxxxx wrote:
        Fastest: ...function inlining and register renaming...
        Fastest, smallest: ...enables all 'Faster' optimizations that do not typically increase code size.
        Well "Fastest, smallest" seems to be wrong, it does not use inlined functions so the code will be slow.
        Just use "Fastest", the size of binary is not as important I think.
        What is about "Enable SSE3 extensions" switch, can it be used???
          On 16/02/2007 at 06:26, xxxxxxxx wrote:
          Ah!! Cool, maybe that is the problem. I clearly have misunderstood the explanation (I should read more carefully *cough* ). Great thanks for pointing this out Remo!
          I don´t know if it can be used without problems? The processors from the last years should all support SSE so it shouldn´t do anything wrong there but I am not quite in that topic to know for sure. 🙂
            On 17/02/2007 at 08:31, xxxxxxxx wrote:
            Normally you have to turn on SSE in a seperate option. I think only the Intel compiler can automatically vectorize code by using SIMD instructions ( and even this requires some manual tweaking due to alignment and data dependency issues ). So you probably have to use intrinsics, which gcc on the mac should support
              On 19/02/2007 at 13:56, xxxxxxxx wrote:
              Hmm, I have now set it to Fastest but it´s still as slow as before. 😕 It´s unbelievable, does anybody have an idea what the problem could be?
              What are the most appropriate settings for a fast compile? I think the default SDK project should at least have this set, so one can see how to set up.
              Anybody from the support an idea?
                On 20/02/2007 at 07:53, xxxxxxxx wrote:
                Where do you have set it to Fastest?
                In "Target" -> "ProjectName" ?
                This is strange but i I double click on "ProjectName", the first in the list then I will get another settings.
                But probably this is not the problem.
                What ca be else?
                Well about SSE3 support: It is only optional and may not supported by all Intel Mac.
                This is also only necessary if one want to use SSE3 intrinsics.
                  On 20/02/2007 at 08:08, xxxxxxxx wrote:
                  Hi Remotion,
                  thanks for answer and yes, I tried setting it in "Target" settings and also in "project name" settings. I also get different settings for both! (the SDK also has different settings).
                  When I change the settings in the project name dialog, then these settings are transferred to the target settings too! But the other way round, so when I set in the Target settings something, then the project settings don´t get changed.
                  So which settings are the important ones? And what effect does each have on the built product? Why are there 2 settings at all?
                  This is absolutely bullsh*t. I hate this compiler. I already had probs with Codewarrior but this fu**** up compiler does never do what I expect. Argh, I am really raging here because it destroys anything like "development dateline" and although MAXON introduced the XCode compiler since 9.6 there is absolutely no information on anything but the switch, which makes working professionally a PITA. Not really what I call supporting a compiler. I wished there was more info on using XCode for C4D development. 😞
                  And pity with the SSE3 support! Thanks for the info!
                    On 20/02/2007 at 08:17, xxxxxxxx wrote:
                    I think "Target" -> "ProjectName" is the important settings, not sure about another one.
                    The SSE and SSE2 support are enabled per default with XCode
                    for Intel compile and in most cases SSE and SSE2 intrinsics are enough.
                      On 20/02/2007 at 08:21, xxxxxxxx wrote:
                      thanks Remo
                        On 20/02/2007 at 08:37, xxxxxxxx wrote:
                        Do you have disabled "Fix & Continue" and other debug stuff ?
                          On 20/02/2007 at 08:53, xxxxxxxx wrote:
                          Hmm, where do I find the "Fix & Continue" option? I have disabled everything that could possibly add any debug information. What is that Fix & Continue?
                          thx
                            On 20/02/2007 at 08:58, xxxxxxxx wrote:
                            ah I have found it. It´s turned off.
                              On 20/02/2007 at 10:32, xxxxxxxx wrote:
                              I now tried every possible option combinations, every optimisation combinations, with same settings as C4D SDK project, custom settings etc..
                              There is absolutely no speed up noticable. 😞
                                On 22/02/2007 at 14:31, xxxxxxxx wrote:
                                Support? I need this resolved. MAXON forces the devs to use this compiler and says it supports only this one, so I should be able to expect some support for it.
                                Thank you in advance
                                  On 03/03/2007 at 09:53, xxxxxxxx wrote:
                                  Push...and I´ll push until I get a supportive answer.
                                    On 03/03/2007 at 12:19, xxxxxxxx wrote:
                                    I'm with Katachi on this one. I'll be back here soon to have an indepth discussion with dev support and possibly the developers about the continuing random crashes in my plugins - it has been noted on CGTalk that once all plugins are removed (not just mine), stability is good - with plugins bad.
                                    This certainly isn't the fault of plugin developers, is linked pretty heavily to R10 and XCode (but not exclusively XCode), and is not only frustrating but infuriating (how do you debug random crashes that have no direct connection to your plugin - i.e.: the crashes do not even mention your plugin but you know there is a connection?). I haven't even figured out how to do a debug with XCode for C4D plugins - as Katachi will agree.
                                    To sort of steer my post back to the topic, I have noticed the same types of incredibly slow behavioural response on the Intel Mac running R10 UB. AM sliders that show no sign of sluggishness whatsoever in R9.6 UB (!) constantly raise the 'beach ball' in R10 UB. This can't be my code (!!), now can it (hint - it's the same code for both builds).
                                    I apologize for the long rant and diversionary tactics...
                                      On 06/03/2007 at 07:01, xxxxxxxx wrote:
                                      First of all, it seems that you don't use the project file the comes with the C4DSDK at all. Generally there is no need to change any of the settings except for the name after duplication.
                                      To optimize, use Shark on the Mac to see where the hotspots in your application are. GCC has different characteristics and optimizations than Microsoft compilers.
                                      Try to make the behaviour reproducable and send a small example including source code to MAXON. Especially when there's a difference between R9.6 UB and R10 UB this indicates there is a secondary problem.
                                        Sure I do.
                                        Actually, you do have to change the sources (duh) and the search paths for headers (my headers - duh II) in the least and in my case there are additional libs added. I don't compile in my default Cinema 4D install for very valid reasons - on any system (Windows, Win x64, MacOS PPC, or MacOSX). But I do always work from a copy of the Resource folder.
                                        My project is a thousand times more complex that that simplistic sdk example lib (it is an application almost in its own right) and consists of 14 plugins (so far) together (in a suite) that work in tandem. Previously, I required exceptions be enabled for a third-party source, but have since modified that code to remove the need for exceptions - enabled exceptions caused no end of pain with delete() and delete (they be Maxon's). I also use zlib support. Great when YOU don't need to do anything complicated or beyond the SDK. Not so great when I have to though...
                                          On 06/03/2007 at 12:10, xxxxxxxx wrote:
                                          The answer refers to the initial poster. Changing sources and adding libraries doesn't affect any project settings!
                                          Of course settings have to be adapted in lots of cases, but the point is that you only should change things when you fully understand how the compiler is working. Apple offers free documentation for XCode and related tools (like Shark). ZLib doesn't conflict with the C4D API and for new/delete there's a workaround by moving the code to a DLL.
                                          Back to the original topic: try to nail down the slowdown, then Maxon support will be able to help.
                                            On 06/03/2007 at 12:15, xxxxxxxx wrote:
                                            I don't think that the original poster wouldn't use the project file that comes with the SDK example plugin - he's been around this SDK much longer than I. 🙂
