    Beginners Question
    2 Posts 0 Posters 236 Views
      On 26/01/2007 at 20:22, xxxxxxxx wrote:
      Cinema 4D Version:   9,1
      i've just started with the C++ Cinema SDK.
      How can i change a value of an Object?
      For example the Radius of a Sphere or the texture filename of a Channel.
      I understand that i can get a container by calling BaseObject::GetData() and use this container to change values. But I don't know where i can find the values (IDS) for a given object.
      Sorry for my english
        On 26/01/2007 at 22:11, xxxxxxxx wrote:
        the easiest way to obtain the description IDs is to drag the description element into the Console input field.
        for instance to change the radius of a sphere your code should look like this:
        BaseContainer *data = op->GetDataInstance();
        data->SetReal(PRIM_SPHERE_RAD, 50);
        op->Message(MSG_UPDATE);
        EventAdd();
        If you change lready existing objects don't forget to use AddUndo/EndUndo to let the users undo/redo their action.
