    Get container of a plugin tag
    3 Posts 0 Posters 311 Views
      On 22/01/2007 at 09:24, xxxxxxxx wrote:
      Cinema 4D Version:   9.603
      I am not sure if I can clearly explain, what my problem is, but I'll try it anyway 😉
      I am in the middle of making a non-modal dialog. This dialog should actually only receive data from a expressionplugintag, and - after values are input - store the dialog values back to the plugintag.
      This sort of works, but strangely not all values are stored correctly in the expressionplugin tag. I can see no pattern, which values are stored and which are not - only that always the same parameters are affected.
      If another expressionplugintag is involved, completely different parameters are stored or not stored - again with no apparent pattern....?
      in both plugins (the non-modal dialog and the expressionplugintag) the basecontainer is indexed by an enum variable....
      Any ideas, why some values are sent/received correctly and others not?
      Or, if a basecontainer is not suited for this (approx. 60 parameters) what else can I use to access/store tag data?
      Sorry for this complicated posting 😉
      André
        On 22/01/2007 at 14:47, xxxxxxxx wrote:
        Sorry...
        Just the good-oldfashioned error 99: change operator.
        I missed some init-functions, which are a relict, from when the expressionplugintag had a dialog itself....
        André
          On 24/01/2007 at 14:24, xxxxxxxx wrote:
          So it's working now for you?
