    HPB to Euler (yet again)
    19 Posts 0 Posters 3.1k Views
      On 22/01/2007 at 10:59, xxxxxxxx wrote:
      Okay, here's an instance where your anti-gimbal-lock and/or other system oddities (unknown) screw me over (I'm being nice).
      The Body of my figure is the root plugin bone. The Polygon object to which it is parented has a unit matrix. This bone has no orientation (0,0,0) and a YXZ rotation order (this is, what, about as close to C4D's HPB as you can get).
      The following YXZ values are what is set on the sliders. The HPB values are what is shown in the object's Coord. tab. The method that you saw above (rmat = orient * rot3 * rot2 * rot1) is how I go from the YXZ to proper HPB equivalents through the matrix.
      Y   X   Z       H   P   B
      0   0   0       0   0   0
      90   0   0      90   0   0
      90 90   0      90   0 270 (?)
      0 90   0       0 90   0
      90 90 90       0 -90 180 (?)
      180 180 180       0   0 360 (?)
      0 180 180     180   0   0 (?)
      0 180   0     180   0 180 (?)
      And so on. Look, the *results* are equivalent - that is, the resulting rotation of the object is exactly proper. But the values are far from equivalent. Remember that these orders are not juxtaposed in any way - Y~=H, X~=P, Z~=B (supposedly).
      This is what I get going from YXZ to HPB. And I need to get from HPB to YXZ so that it looks like this (should look familiar - I just swapped the columnar sets) :
      H   P   B           Y   X   Z
      0   0   0           0   0   0
      90   0   0          90   0   0
      90   0 270 (?)      90 90   0
      0 90   0           0 90   0
      0 -90 180 (?)      90 90 90
      0   0 360 (?)     180 180 180
      180   0   0 (?)       0 180 180
      180   0 180 (?)       0 180   0
      If this cannot be achieved, I'm screwed. Variable equivalences wreak havoc over a skeletal hierarchy. It can't just go from (0, 180, 0) to (180, 0, 180) and whatever results in between without causing 'strange yoga'.
      For some reason, everyone keeps saying that C4D HPB is plain-old Euler - BS! Then the values above would be identical! Poser's rotations are plain-old Euler and I've used plain-old Euler code (Shoemake and Eberly - PhDs in mathematics both). Explain the differences and I might find a way...
        On 22/01/2007 at 14:55, xxxxxxxx wrote:
        Okay, the IK solution is sort of working! There seems to be a 'jitter' as some of the rotation slider values toggle back and forth between positive and negative. Not sure why that is occuring yet, but no more spaghetti! What helped solve this is setting the slider values (allowing for full compliance - including master-slave changes) along with the IPP_ROTATION vector but without applying the values to the object (which would set the local matrix and cause an infinite loop or crash).
        Once the mystery jitter can be resolved, I'll post the code.
          On 23/01/2007 at 00:24, xxxxxxxx wrote:
          As promised, the code:
          // IPPBase.HPBToPoser -          Convert HPB to Poser ordered-Euler angles
          void IPPBase::HPBToPoser()
               BaseTag*          dialTag;
               BaseContainer*     dialBC;
               Matrix               mat;
               Vector               v1, v2, v3;
               BaseTime          docTime =     document->GetTime();
               // Switch over to the dials' SetValueIK() method
               ikEnabled =          TRUE;
               // Check every body part for IK (Kinematic Tag)
               for (LONG m = bpindex; m >= FIRST_BPINDEX; --m)
                    bone =          subBC->GetObjectLink(m, document);
                    if (!bone)     continue;
                    if (!bone->GetTag(Tkinematic))     continue;
                    bbc =          bone->GetDataInstance();
                    if (!bbc)     continue;
                    // Remove Orientation from Rotation Matrix
                    mat =          HPBToMatrix(bone->GetRot()) * !bbc->GetMatrix(IPP_ORIENTMATRIX);
                    v1 =          mat.v1;
                    v2 =          mat.v2;
                    v3 =          mat.v3;
                    // Take into account Rotation Order and extract Euler angles
                    switch (bbc->GetLong(IPP_RORDER))
                         case ROTORDER_XYZ:
                              y =               asin(v1.z);
                              if (y < pi05)
                                   if (y > -pi05)
                                        x = Angle(-v2.z, v3.z);
                                        z = Angle(-v1.y, v1.x);
                                   else
                                        x = -Angle(v2.x, v2.y);
                                        z =     0.0;
                              else
                                   x = Angle(v2.x, v2.y);
                                   z =     0.0;
                              break;
                         case ROTORDER_XZY:
                              z =               asin(-v1.y);
                              if (z < pi05)
                                   if (z > -pi05)
                                        x = Angle(v3.y, v2.y);
                                        y = Angle(v1.z, v1.x);
                                   else
                                        x = -Angle(-v3.x, v3.z);
                                        y =     0.0;
                              else
                                   x = Angle(-v3.x, v3.z);
                                   y =     0.0;
                              break;
                         case ROTORDER_YXZ:
                              x =               asin(-v2.z);
                              if (x < pi05)
                                   if (x > -pi05)
                                        y = Angle(v1.z, v3.z);
                                        z = Angle(v2.x, v2.y);
                                   else
                                        y = -Angle(-v1.y, v1.x);
                                        z =     0.0;
                              else
                                   y = Angle(-v1.y, v1.x);
                                   z =     0.0;
                              break;
                         case ROTORDER_YZX:
                              z =               asin(v2.x);
                              if (z < pi05)
                                   if (z > -pi05)
                                        y = Angle(-v3.x, v1.x);
                                        x = Angle(-v2.z, v2.y);
                                   else
                                        y = -Angle(v3.y, v3.z);
                                        x =     0.0;
                              else
                                   y = Angle(v3.y, v3.z);
                                   x =     0.0;
                              break;
                         case ROTORDER_ZXY:
                              x =               asin(v3.y);
                              if (x < pi05)
                                   if (x > -pi05)
                                        z = Angle(-v1.y, v2.y);
                                        y = Angle(-v3.x, v3.z);
                                   else
                                        z = -Angle(v1.z, v1.x);
                                        y =     0.0;
                              else
                                   z = Angle(v1.z, v1.x);
                                   y =     0.0;
                              break;
                         case ROTORDER_ZYX:
                              y =               asin(-v3.x);
                              if (y < pi05)
                                   if (y > -pi05)
                                        z = Angle(v2.x, v1.x);
                                        x = Angle(v3.y, v3.z);
                                   else
                                        z = -Angle(-v1.y, v1.z);
                                        x =     0.0;
                              else
                                   z = Angle(-v1.y, v1.z);
                                   x =     0.0;
                              break;
                    //v1 =     Vector(x,y,z);
                    //GePrint(bbc->GetString(IPP_INTERNALNAME)+" "+VectorToString(v1-bbc->GetVector(IPP_ROTATION), TRUE));
                    bbc->SetVector(IPP_ROTATION, Vector(x,y,z));
                    // Set Dial Sliders to reflect IK rotations
                    dialTag =                         (BaseTag* )bbc->GetLink(IPP_DIAL_ROTX, document);
                    if (dialTag)
                         dialBC =                    dialTag->GetDataInstance();
                         SetKey(document, docTime, bone, dialTag, dialBC, dialBC->GetLong(IPPDIAL_INDEX), ToDeg(x), TRUE);
                    dialTag =                         (BaseTag* )bbc->GetLink(IPP_DIAL_ROTY, document);
                    if (dialTag)
                         SetKey(document, docTime, bone, dialTag, dialBC, dialBC->GetLong(IPPDIAL_INDEX), ToDeg(y), TRUE);
                    dialTag =                         (BaseTag* )bbc->GetLink(IPP_DIAL_ROTZ, document);
                    if (dialTag)
                         SetKey(document, docTime, bone, dialTag, dialBC, dialBC->GetLong(IPPDIAL_INDEX), ToDeg(-z), TRUE);
               // Switch back to the dials' SetValue() method
               ikEnabled =          FALSE;
          Some words on this code:
          1. ikEnabled is used to set the method which is used to set the slider values - don't want to actually set the object matrix or the result would be an infinite loop. This signals not to do that.
          2. My skeletal hierarchy is stored in a BaseContainer for fast retrieval (instead of recursive methods over the objects in the OM).
          3. IPP_ORIENTMATRIX is a rotation matrix for the plugin bone initial orientation (Poser). This is independent of the rotations of the bone.
          4. x,y,z are Real variables.
          5. The bottom section outside of the body part loop just sets the IPP_ROTATION vector (stored Poser Euler rotations in radians) and the sliders themselves. Most likely not of consequence for the general solution.
          6. Angle() is a wrapper for atan2() which considers certain special situations:
          // Return Real angle (in radians) whose tangent = y/x
          Real Angle(Real y, Real x)
               if (Abs(x) < 0.000001)
                    if (Abs(y) < 0.000001) return 0.0;
                    if (y > 0.0) return (RAD_90);
                    return (RAD_270);
               return atan2(y,x);
          Thanks!
            On 23/01/2007 at 02:59, xxxxxxxx wrote:
            Hello kuroyume0161,
            that will help me very much! I will analyze the code and once I got it fully it will be very useful.
            Thansk a lot for your support,
            Coffejunkie
              On 29/01/2007 at 12:23, xxxxxxxx wrote:
              Looks that there are still inconsistencies. The three test figures all worked - a first still. Other figures show signs of the rotations varying though.
              Not as much jumping, but a chaotic wandering - probably a feedback situation as slight variances in the HPB to Poser conversion values are then set in the Poser values which are used for further rotations which are converted (etc.).
              Jumping does occur when certain rotation values go above 90d (on two axes).
              One problem here is that the HPBToPoser() conversion sets all three Euler rotations - there is no way around this.
              Gosh, could I use the collaboration of a mathematician in this (how to avoid the wandering) - or something. The jumping points to Cinema 4D-specific information that needs disclosing.
              Robert
                On 19/04/2007 at 18:07, xxxxxxxx wrote:
                A final thought:
                This problem is intractable. This is not Cinema 4D's fault, just one where there is no singular solution to extraction of Euler angles from matrices or quaternions. If Cinema 4D didn't have the anti-gimballock mechanism, the Poser and Cinema 4D rotations might always match. But I'm not going to chide Maxon for employing the mechanism. So it is from-scratch wherever rotations are involved.
                I've emailed back and forth with Dave Eberly (yes, the man himself) and he agrees with this assessment.
                  On 20/04/2007 at 10:12, xxxxxxxx wrote:
                  Hello everybody,
                  it seems to me, that this makes a BVH-export from cinema for other applications impossible. That's a pitty especially as someone less firm with these gimbal-lock-problems or the mathematical theory behind the HPB-to-Euler-Problem of course will wonder why cinema imports this format but does not export it. Wouldn't it be great to have a parameter inside cinema, that gives the user the possebility to choose between HPB or Euler-angles?
                  It must be technically possible to make an animation-system work with Euler, poser proves this. So if this ist possible, why not making all cinema work with it? I know this will be a lot of work for Maxons's programmers , as they will have to change the programm in many ways. But it would be great for users.
                  Of course then it will not be possible to change between these systems when there are already rotatable objects in a scene, but all the time before this point perhaps?
                  Well HPB is a quite clever system, no doubt.
                  Just one question to be sure I understood everything right here:
                  When I got a poser import form BVH which is set to correct HPB-values on import in cinema and I try to store the original angles of any local bone additional.
                  Will I get the problem to, tracking rotational changes in the HPB-system directly to the euler-angles? If I understood everything correct I would think so, just wanted to be sure.
                  Because if not, I could export these Euler values back to poser afterwards. Although I would need some startvalues in Euler.
                  Best whishes,
                  Coffejunkie
                  PS: Let's hope for Maxon's inovations on Cinema in future, dreaming is always possible 😉
                    On 20/04/2007 at 10:51, xxxxxxxx wrote:
                    Yes.
                    The BVH rotations cause correct HPB values by matrix concatenation of the rotations in proper Euler order. The problem is going the other way - extracting Euler rotation angles from a matrix always has multiple solutions (even if you know the order of the rotations).
                    Further, assuming that the HPB rotations can be equivocated back to the same Euler rotations (even knowing the order of rotations) will eventually get you into trouble. The reason is that HPB does some shuffling of rotation values in order to avoid gimbal lock. If all of the HPB rotations are less than 90d, you will more than likely have an exact relationship between HPB and Euler. After that, the relationship most likely will not hold.
                    With a small plugin, I rotated a single object through all three axes in six Euler orders (XYZ, XZY, YXZ, YZX, ZXY, ZYX) by increments of 90d (0,90,180,270). The original Euler rotations, the resulting HPB (from matrix concatenation), and the 'best converted' Euler rotations were tabulated. The results were that a large percentage of the Euler rotations (of the same Euler order) produced the same HPB rotations - that is, three/four/five different Euler rotations had the exact same HPB rotation (we're not even talking about conversion back to Euler yet!). At that point, there is no way to know which of the possible Euler rotations resulted in the particular HPB. Which one? Who knows...
                    For animation and, especially, CA this is not acceptable. It sort of presents the same problem as MOCCA's Quaternion tag - there, any rotation beyond 180d is going to cause problems as this tag always looks for the shortest rotation path (which will always be 180d or less). So you end up with a completely different rotation result - which is similar to what I experienced when attempting to convert HPB changes back to similar changes in Poser's Euler ordered rotations. 180,0,180 may be equivalent to 0,180,0 in the direction vector but you can imagine how deformations applied according to individual axial rotations will differ between the two.
                      On 23/04/2007 at 02:56, xxxxxxxx wrote:
                      How can this result in the same rotation ??
                      Y   X   Z       H   P   B
                      to my understanding
                      XYZ should align the local Z axis parallel to world Y axis
                      HPB should align the local Z axis parallel to world X axis
                        On 05/02/2017 at 02:45, xxxxxxxx wrote:
                        I'm aware that this is a very old post, but 10 years later it is still a problem to get Poser figures to Cinema 4D and animate them there, because of the different rotation system.
                        Unfortunately Robert is no longer around and so I wonder, if someone else has more information or if there was already an existing solution discussed, how to map XYZ rotation to HPB.
