    Set Keyframes
    SDK Help
    0
    • H
      On 16/01/2007 at 12:14, xxxxxxxx wrote:
      Cinema 4D Version:   R10
      Hi everybody,
      it seems that keyframing I did in previous versions does not work with R10 anymore. Do you have any experience with it? I know, that the timeline/track/sequence things somehow changed.
      But how can I set keyframes?
      And: Where can I download SDK for R10. Isn't it ready.
      Thanks for your help
      Chris
      • H
        On 16/01/2007 at 13:56, xxxxxxxx wrote:
        Yes, track/sequence/keys are no longer represented by BaseTrack/BaseSequence/BaseKey - they are deprecated. You must now use CTrack/CCurve/CKey, CCurve being automatically added to the track.
        The SDK itself is included with R10, but the SDK documentation still isn't ready it seems.
        • H
          On 16/01/2007 at 23:49, xxxxxxxx wrote:
          Thanks for the answer!
          Has anybody a small samplecode for this?
          Chris
          • H
            On 17/01/2007 at 01:36, xxxxxxxx wrote:
            Check out the Morphmixer example in the SDK, especially the static CreateKey function.
            • H
              On 18/01/2007 at 01:02, xxxxxxxx wrote:
              Hello Matthias,
              have you already used the CreateKey function?
              I transfered it to my plugin and I can complie, but
              I don't know, what parameters I have to pass.
              What is the Index? Is this ID_BASEOBJECT_POSITION for position?
              What about the value. It is just a REAL. But a position is a vector.
              Before, I used code I found here in the forum. I set it to the end.
              Chris
               if(mybo)
                p = mybo->GetPos();
                val[0] = p.x;
                val[1] = p.y;
                val[2] = p.z;
               else return FALSE;
               for (ii=0; ii<3; ii++)
               // check if track exists
               descID = DescID(DescLevel(ID_BASEOBJECT_POSITION, 0, 0), DescLevel(VECTOR_X+ii, 0, 0));
               track = mybo->FindTrack(descID);
               if (!track)
                track = AllocValueTrack(mybo,descID); if (!track) return FALSE;
                mybo->InsertTrackLast(track);
               // check for sequence
               seq = NULL;
               for (seq = track->GetFirstSequence(); seq; seq=seq->GetNext())
               if (time>=seq->GetT1() && time<=seq->GetT2())
                break;
               if (!seq)
                seq = track->AutoAddSequence(mydoc,time);
                if (!seq) return FALSE;
               key = BaseKey::Alloc(seq->GetType()); if (!key) return FALSE;
               av = GetKeyValue(key); if (!av) return FALSE;
               av->value = val[ii];
               key->SetTime(time);
               seq->InsertKey(key);
              • H
                On 18/01/2007 at 04:18, xxxxxxxx wrote:
                Yeah ID_BASEOBJECT_POSITION is the ID for the position. Here is some sample code, it is the modified Morphmixer that records a hidden vector parameter. Remember that there are no sequences anymore and everything is now working with DescIDs.
                #include "c4d.h"
                #include "c4d_symbols.h"
                #include "omorphmixer.h"
                class MorphMixerObject : public ObjectData
                     INSTANCEOF(MorphMixerObject,ObjectData)
                          virtual Bool Init(GeListNode* node);
                          virtual Bool Message(GeListNode *node, LONG type, void *data);
                          virtual BaseObject* GetVirtualObjects(PluginObject *op, HierarchyHelp *hh);
                          virtual Bool GetDDescription(GeListNode *node, Description *description,LONG &flags;);
                          static NodeData *Alloc(void) { return gNew MorphMixerObject; }
                static Bool CreateKey(BaseDocument *doc, BaseObject *op, const BaseTime &time;, LONG index, Vector value)
                     CTrack *trackx = op->FindCTrack(DescID(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),DescLevel(VECTOR_X,DTYPE_REAL,0)));
                     if (!trackx)
                          trackx = CTrack::Alloc(op,DescID(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),DescLevel(VECTOR_X,DTYPE_REAL,0))); if (!trackx) return FALSE;
                          op->InsertTrackSorted(trackx);
                     CKey *key = trackx->GetCurve()->AddKey(time); if (!key) return FALSE;
                     key->SetValue(trackx->GetCurve(),value.x);
                     CTrack *tracky = op->FindCTrack(DescID(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),DescLevel(VECTOR_Y,DTYPE_REAL,0)));
                     if (!tracky)
                          tracky = CTrack::Alloc(op,DescID(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),DescLevel(VECTOR_Y,DTYPE_REAL,0))); if (!tracky) return FALSE;
                          op->InsertTrackSorted(tracky);
                     key = tracky->GetCurve()->AddKey(time); if (!key) return FALSE;
                     key->SetValue(tracky->GetCurve(),value.y);
                     CTrack *trackz = op->FindCTrack(DescID(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),DescLevel(VECTOR_Z,DTYPE_REAL,0)));
                     if (!trackz)
                          trackz = CTrack::Alloc(op,DescID(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),DescLevel(VECTOR_Z,DTYPE_REAL,0))); if (!trackz) return FALSE;
                          op->InsertTrackSorted(trackz);
                     key = trackz->GetCurve()->AddKey(time); if (!key) return FALSE;
                     key->SetValue(trackz->GetCurve(),value.z);
                Bool MorphMixerObject::Init(GeListNode *node)
                Bool MorphMixerObject::GetDDescription(GeListNode *node, Description *description,LONG &flags;)
                     if (!description->LoadDescription(node->GetType())) return FALSE;
                     BaseContainer bc2 = GetCustomDataTypeDefault(DTYPE_VECTOR);
                     bc2.SetBool(DESC_HIDE,TRUE);
                     bc2.SetString(DESC_NAME,"Test");
                     bc2.SetString(DESC_SHORT_NAME,"Test");
                     if (!description->SetParameter(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),bc2,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
                     return SUPER::GetDDescription(node,description,flags);
                Bool MorphMixerObject::Message(GeListNode *node, LONG type, void *data)
                     switch (type)
                          case MSG_DESCRIPTION_COMMAND:
                               DescriptionCommand *dc = (DescriptionCommand* ) data;
                               if (dc->id[0].id==MORPHMIXER_RECORD)
                                    BaseObject          *op = (BaseObject* )node;
                                    BaseDocument     *doc = node->GetDocument(); if (!doc) break;
                                    CreateKey(doc,op,doc->GetTime(),MORPHMIXER_POSEOFFSET,Vector(1,2,3));
                                    EventAdd();
                // create morphed object
                BaseObject *MorphMixerObject::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
                     return NULL;
                // be sure to use unique IDs obtained from www.plugincafe.com
                #define ID_MORPHMIXER_OBJECT     1001156
                Bool RegisterMorphMixer(void)
                     // decide by name if the plugin shall be registered - just for user convenience
                     String name=GeLoadString(IDS_MORPHMIXER); if (!name.Content()) return TRUE;
                     return RegisterObjectPlugin(ID_MORPHMIXER_OBJECT,name,OBJECT_GENERATOR|OBJECT_INPUT,MorphMixerObject::Alloc,"Omorphmixer","morphmixer.tif",0);
                hope that helps
                • H
                  On 18/01/2007 at 05:45, xxxxxxxx wrote:
                  Yes! Thank you very much!
