    Dynamic Descriptions
    2 Posts 0 Posters 309 Views
      On 12/01/2007 at 04:19, xxxxxxxx wrote:
      Cinema 4D Version:   9.507
      Hi everyone,
      i got a description file with some entries and a button. If the user clicks on that button, the description file should be extended by some other values.
      The Buttons are controlled by
           Bool TagCone::Message(GeListNode *node, LONG type, void *data)
      and the dynamic description is defined with
           Bool TagCone::GetDDescription(GeListNode *node, Description *description, LONG &flags)
      Is it possible to call the GetDDescription function from the message function (so that the description file will be extended by the entries defined in the GetDDescription function when i press the button)?
      if i just try to insert
           GetDDescription(node, description, flags);
      in the message function i don't know which parameters i have to insert in this function call...
      Hope somone does understand what i mean ^^
        On 14/01/2007 at 14:43, xxxxxxxx wrote:
        GetDDescription is called whenever anything happens in the descriptions (AM). There is absolutely no need to call it from the message function.
        Instead, use a class member variable that stores what should be added and then use it when GetDDescription is called.
        That easy 🙂
