    Row Vector
    5 Posts 0 Posters 525 Views
      On 24/11/2006 at 04:34, xxxxxxxx wrote:
      Cinema 4D Version:   R9.507
      Hi i have got just a little layout problem. I have a description file with some vectors. They are shown as column vectors. Is there a way to show them as row vectors?
      Thx
        On 24/11/2006 at 18:11, xxxxxxxx wrote:
        Can I take a look at your code sample?
        Zaw Min Tun
          On 28/11/2006 at 00:03, xxxxxxxx wrote:
          GROUP COM_GROUP
          DEFAULT 1;
          VECTOR COM {UNIT METER; STEP 0.1; CUSTOMGUI SUBDESCRIPTION;}
            On 28/11/2006 at 01:07, xxxxxxxx wrote:
            The Vector 'customgui' (which is used for all vectors either in dialogs, the Attributes Manager, or elsewhere) only shows vectors as row vectors. As far as I know, there is no way to change it.
            For a dialog, you could set up a set of three gadgets, one for each vector component, and then set them according to the vector component values. You don't get the convenience of GetVector() - you have to use GetReal() for each component gadget.
            For a customgui like in the Attributes Manager, you could do the same thing, but you'd have to do this instead:
            GROUP COM_GROUP
            DEFAULT 1;
            REAL COM_X {...}
            REAL COM_Y {...}
            REAL COM_Z {...}
              On 28/11/2006 at 04:38, xxxxxxxx wrote:
              Ok thanks, thats the same way i tried to avoid the standart notation of vectors
