    XCode and new 'new' errors!!
    11 Posts 0 Posters 1.1k Views
      On 23/11/2006 at 16:19, xxxxxxxx wrote:
      Got it. Order of includes (?). The order and included files hadn't changed - very weird.
      Back to final two compiles...
        On 10/07/2008 at 11:26, xxxxxxxx wrote:
        Hey Rob,
        can you tell me which includes you mean here as I have the same problem here (just on PC)
          On 10/07/2008 at 17:25, xxxxxxxx wrote:
          I don't know - it's been a year and a half and this was Xcode complaining.
          It may be related to exceptions and it sounds like I changed the order of <c4d.h> and <new.h>. Are you including any Windows headers?
            On 11/07/2008 at 03:08, xxxxxxxx wrote:
            nope, no windows headers only STL. Never had a problem, but now I installed the 2008 express version at home and after conversion from my project it gives me these errors.
            I am using exceptions but turning it off doesn´t work. The errors remain. I will try changing some includes when I am home, maybe it helps. Otherwise I´ll be needing to install my full version at home too. But it´s strange anyway that this always happens.
            thx anyway
              On 30/03/2009 at 07:29, xxxxxxxx wrote:
              I reinstalled OSX 10.5.6, Xcode and C4D R10.111 and now i have the same problem. Do you guys by any chance remeber the solution? This is weird, becuase i had the same config before (same osx, same xcode, same c4d) and no problems at all!
              Ok, i just remembered that i did something else. I needed exceptions and enabled "C++ Exceptions" in the project settings. If i disable them the errors disappear. the problem is, i really need exceptions.
              here are the errors i get when exceptions are enabled:
              Any idea how i could get it to work?
                On 02/04/2009 at 00:03, xxxxxxxx wrote:
                solved. it was really just the order of includes. im using tinyxml and putting the tinyxml.h before c4d.h solved it!
                  On 02/04/2009 at 00:41, xxxxxxxx wrote:
                  This is also what the docu recommends.
                  from the 'Stability and Testing' chapter:
                  CINEMA 4D and OS code
                  -Include OS headers before CINEMA 4D headers
                    On 02/04/2009 at 02:22, xxxxxxxx wrote:
                    yes Matthias, i will definitely check the manual next time!
                    now... i ran into the next problem. after fixing all the includes im now getting a linker error on all files using gNew:
                    i wonder were all those issues came from. i already regret reinstalling osx...
                    if anyone has a clue, please let me know 🙂
                      On 03/04/2009 at 02:27, xxxxxxxx wrote:
                      btw: building the c4d sdk examples with c++ eceptions enabled raises the same error.
                        On 07/04/2009 at 03:01, xxxxxxxx wrote:
                        ok here comes a stupid question: is it possible at all to build with c++ exceptions enabled under osx?
                        edit: C4D R10.111, OSX 10.5.6, latest Xcode
