    script not working in r10
    9 Posts 0 Posters 769 Views
      On 06/11/2006 at 08:58, xxxxxxxx wrote:
      Cinema 4D Version:   10
      I have a question regarding a script:
      I am still using C4d 9.6,
      and I use this script to toggle color for the Grids and Viewport background at once, when I switch between dark and light layouts. For some reason it does not seem to work anymore with r10 (demo).
      Can anyone help me as to why that is?
      the script:
      var bgcolor = GetWorldContainer();
      var rgb = 256.0;
      var R = 170;
      var G = 170;
      var B = 170;
      var B1 = vector(R/rgb,G/rgb,B/rgb);
      var r = 70;
      var g = 70;
      var b = 70;
      var B2 = vector(r/rgb,g/rgb,b/rgb);
      if (bgcolor->GetData(WPREF_BACKGROUND_COL) == B1)
      bgcolor->SetData(WPREF_BACKGROUND_COL , B2);
      else
      bgcolor->SetData(WPREF_BACKGROUND_COL , B1);
      SetWorldContainer(bgcolor);
      var Gcolor = GetWorldContainer();
      var rgb = 256.0;
      var R = 120;
      var G = 120;
      var B = 120;
      var G1 = vector(R/rgb,G/rgb,B/rgb);
      var r = 135;
      var g = 135;
      var b = 135;
      var G2 = vector(r/rgb,g/rgb,b/rgb);
      if (bgcolor->GetData(WPREF_GRID_MAJOR_COL) == G1)
      bgcolor->SetData(WPREF_GRID_MAJOR_COL , G2);
      else
      bgcolor->SetData(WPREF_GRID_MAJOR_COL , G1);
      var rgb = 256.0;
      var R = 150;
      var G = 150;
      var B = 150;
      var M1 = vector(R/rgb,G/rgb,B/rgb);
      var r = 95;
      var g = 95;
      var b = 95;
      var M2 = vector(r/rgb,g/rgb,b/rgb);
      if (bgcolor->GetData(WPREF_GRID_MINOR_COL) == M1)
      bgcolor->SetData(WPREF_GRID_MINOR_COL , M2);
      else
      bgcolor->SetData(WPREF_GRID_MINOR_COL , M1);
        On 07/11/2006 at 16:21, xxxxxxxx wrote:
        Using a very similar script and would also like to see what to do to get it running in R10 🙂
        Lennart
          On 08/11/2006 at 02:34, xxxxxxxx wrote:
          The WPREF_XXX_COL identifiers are not declared anymore in R10. I have to look how you can set the colors in COFFEE now.
            On 07/04/2010 at 16:37, xxxxxxxx wrote:
            Did this make it back?
            Or how would we control the background color now?
            Lennart
              On 08/04/2010 at 00:07, xxxxxxxx wrote:
              Have a look at coffeesymbols.h in the resource folder: All symbols are defined there. By a quick glance, I would say that VIEWCOLOR_C4DBACKGROUND is a hot candidate.
              Hope it helps
              Kabe
                On 08/04/2010 at 03:43, xxxxxxxx wrote:
                Yup I did find and tried all of those, but that one return a 1,1,1 vector (full white instead of the grey used)
                and the others nil. So still wonder what/how to do.
                Lennart
                  On 10/04/2010 at 19:32, xxxxxxxx wrote:
                  Ok, testing with Python it works visa"GetViewColor()".
                  But that one seems to be undefined by COFFEE.
                  I'm a still missing something or what is it that is changed?
                  Python test:
                  from c4d import symbols as sy
                  dark = c4d.Vector(0.2,0.2,0.2)
                  light = c4d.Vector(0.8,0.8,0.8)
                      col = c4d.GetViewColor(sy.VIEWCOLOR_C4DBACKGROUND)
                      print col
                      if col == dark:
                              c4d.SetViewColor(sy.VIEWCOLOR_C4DBACKGROUND,light)
                      elif col == light:
                              c4d.SetViewColor(sy.VIEWCOLOR_C4DBACKGROUND,dark)
                  Lennart
                    On 12/04/2010 at 02:18, xxxxxxxx wrote:
                    It's currently not possible in COFFEE.
                      On 12/04/2010 at 05:28, xxxxxxxx wrote:
                      Good to see that Python is starting to become a real alternative 🙂
                      Jack
