    basechannel
    5 Posts 0 Posters 429 Views
      On 25/10/2006 at 08:23, xxxxxxxx wrote:
      Cinema 4D Version:   9.6
      Is it possible to retrieve the texture *filename* applied to a material's basechannel? (i.e. the filename of the texture applied in the color channel)
      thanks!
        On 25/10/2006 at 09:42, xxxxxxxx wrote:
        Yes:
        // Get Color Channel
        BaseChannel* bchan = mat->GetChannel(CHANNEL_COLOR);
        if (!bchan) continue;
        // Extract full image file path
        Filename suggestedFolder =     bchan->GetData().GetFilename(BASECHANNEL_SUGGESTEDFOLDER);
        String map = bchan->GetData().GetString(BASECHANNEL_TEXTURE);
        Filename fullpath = suggestedFolder + Filename(map);
          On 25/10/2006 at 09:51, xxxxxxxx wrote:
          works perfectly 😉 thanks!
            On 26/10/2006 at 01:52, xxxxxxxx wrote:
            hmm, i've found out that my current code:
            String map = pChannel- >GetData().GetString(BASECHANNEL_TEXTURE);
            if (map.GetLength() == 0) return FALSE;
            Filename suggestedFolder = pChannel->GetData().GetFilename(BASECHANNEL_SUGGESTEDFOLDER);
            if (suggestedFolder.GetString().GetLength() == 0)
            // same as the document
                 suggestedFolder = pDoc->GetDocumentPath();
            fails to retrieve the right path when the map is located within a subfolder of the main scene location (i.e. on c4d samples, textures are usually located in a 'tex' subfolder).
            This code nevertheless is working fine:
            Filename path;
            GenerateTexturePath(pDoc- >GetDocumentPath(), Filename(pChannel->GetData().GetString(BASECHANNEL_TEXTURE)),
            Filename(), &path;)
            cheers
              On 26/10/2006 at 04:33, xxxxxxxx wrote:
              I clear the suggestedFolder when the texture is made local (wrt the c4d document). When the texture is elsewhere, suggestedFolder has the path to the texture. Should have mentioned that - sorry. :S
