    SNHookClass::Register and C4D Exit Crash!
    2 Posts 0 Posters 249 Views
      On 21/09/2006 at 17:05, xxxxxxxx wrote:
      Cinema 4D Version:   9.102
      This is an urgent problem!
      This is the full code of my main.cpp (minus stuff that wouldn't be good out in public).
      Here's the situation: Only if the user does not run my plugin (or the dialog isn't restored in the layout during startup), C4D is guaranteed to crash on exit Windows/MacOS R8.2-R9.6 confirmed.
      I've narrowed this down to one line (marked below) : the SNHookClass::Register() method. Could it be that the plugin_id in Register() must be different that the main plugin id (doesn't seem to make a difference)? If you see anything that seems out of place otherwise, please do not hesitate to mention it as well.
      // Includes
      #include "c4d.h"
      #include "lib_sn.h"
      #include "general.h"
      // IPPSerial: Serial Number Hook Class
      class IPPSerial : public SNHookClass
           private:
                // Data
                String               SNPluginName;
                // Methods
                // - IPPSerial.checkSerial
                bool               checkSerial(const String& c4dsn, const String& sn)
                     // Code removed for obvious reasons
                     return true;
                // Data
                bool               registered;
                UCHAR               mode;
                UCHAR               time;
                // Methods
                // - Constructor
                IPPSerial()
                     registered = false;
                     SNPluginName = GeLoadString(IPPS_PLUGIN_NAME)+" "+GeLoadString(IPPS_PLUGIN_EDITION);
                // - SNHookClass.SNCheck
                LONG               SNCheck(const String& c4dsn, const String& sn, LONG regdate, LONG curdate)
                     if (!regdate && !sn.Content())               return SN_WRONGNUMBER;
                     // Code removed for obvious reasons!!
                // - SNHookClass.GetTitle
                const String&     GetTitle()
                     return SNPluginName;
      } *ippSerial = NULL;
      // Plugin Functions ==================================================================================================
      #include "interPoserPro.h"
      // Declare Global Plugin Registrants
      interPoserPro* RegisterInterPoserProCommand();
      Bool RegisterIPPBase();
      Bool RegisterIPPFigureTag();
      Bool RegisterIPPObjectTag();
      Bool RegisterIPPDialTag();
      Bool RegisterIPPJointTag();
      Bool RegisterC4DFigureTag();
      Bool RegisterIPPTool();
      Bool PluginStart()
           BOOL     network;
           LONG     vtype = GeGetVersionType();
           if ((vtype & VERSION_SERVER) || (vtype & VERSION_NET))     network = TRUE;
           else        network = FALSE;
           if (!((vtype & VERSION_DEMO) || network))
                // serial number check
                if (!(ippSerial && ippSerial->registered)) return FALSE;
           GePrint(" ");
           GePrint(GeLoadString(IPPS_PLUGIN_BANNER));
           GePrint("-- "+GeLoadString(IPPS_PLUGIN_NAME)+" "+GeLoadString(IPPS_PLUGIN_EDITION)+" v"+GeLoadString(IPPS_PLUGIN_VERSION)+" "+GeLoadString(IPPS_PLUGIN_COPYRIGHT));
           GePrint(" ");
           // register hooks and return
           interPoserPro* ipp =          RegisterInterPoserProCommand();
           if (!ipp)                         return FALSE;
           if (ippSerial && !network)     ipp->SetDemoInfo(ippSerial->mode, ippSerial->time);
           return RegisterIPPFigureTag() && RegisterIPPObjectTag() && RegisterIPPBase() && RegisterIPPDialTag() && RegisterIPPJointTag() && RegisterC4DFigureTag() && RegisterIPPTool();
      void PluginEnd()
           gDelete(ippSerial);
      Bool PluginMessage(LONG id, void* data)
           if          (id == C4DPL_INIT_SYS)
                // initialize global resource object
                if (!resource.Init())     return FALSE;
                // initialize and register Serial Number Hook
                if ((vtype & VERSION_SERVER) || (vtype & VERSION_NET))     return TRUE;
                ippSerial =     gNew IPPSerial();
                if (!ippSerial)     return FALSE;
                // THIS CRASHES C4D ON EXIT
                return ippSerial->Register(ID_INTERPOSERPRO, SNFLAG_OWN);
                //return TRUE;
           else if (id == C4DMSG_PRIORITY)          return TRUE;
           return FALSE;
      Thank you,
        On 21/09/2006 at 22:45, xxxxxxxx wrote:
        After all of that, I traced the problem to the instantiation of the main dialog. If it is only done in CommandData::Execute() and CommandData::RestoreLayout(), then the crash-on-exit disappears.
