    Modify RenderData Container switches
    6 Posts 0 Posters 513 Views
      On 02/09/2006 at 13:50, xxxxxxxx wrote:
      Cinema 4D Version:   9.6
      Ti to All, I write a script to switch on-off some bool gadgets in the render settings panel (I would like to insert to xpresso COFFE node finally).
      I get the active render settings and that container datas what I would like to change. but after using the SetData function doesnt occured anything.
      Can I control render  settings panel from script or xpresso COFFE node?
      Should I refresh something?
      I copy here the whole script what I created:
          main(doc, op)
            var rd=doc->GetFirstRenderData();
            var activeRD;
            var rdName;
           var rdBit;
            // active render setting selection
           while (rd)
             rdName = rd->GetName();
             rdBit = rd->GetBit(BIT_ARDATA);
              if (rdBit == 1) break;
              rd = rd->GetNext();
            // select switches from bc
            println("NAME OF ACTUAL RENDER SETTINGS = " + tostring(rd->GetName()));
           var bc = rd->GetContainer();
           //println(bc->GetData(RDATA_RESOLUTION));
            println("- actual posteffect switch = " + tostring(bc->GetData(RDATA_POSTEFFECTS_ENABLE)));
            println("- actual autolight switch = " + tostring(bc->GetData(RDATA_AUTOLIGHT)));
            //  switch off selected option gadgets in bc
            var result = bc->SetData(RDATA_POSTEFFECTS_ENABLE,FALSE);
            var result = bc->SetData(RDATA_AUTOLIGHT,FALSE);
            //  audit the changed parameters
            println("- set posteffect switch = " + tostring(bc->GetData(RDATA_POSTEFFECTS_ENABLE)));
            println("- set autolight switch = " + tostring(bc->GetData(RDATA_AUTOLIGHT)));
      any suggestion would be cool
      thanks,
      fuxy
        On 05/09/2006 at 04:36, xxxxxxxx wrote:
        Hi all, any idea what is wrong?
        regards,
        Zoltan
          On 05/09/2006 at 07:19, xxxxxxxx wrote:
          Hy fuxi,
          it is just an idea I did not try this out yet, but perhaps sending some message might help? I 'd try doc->Message(DOCUMENT_CHANGED) for example or perhaps something with MSG_UPDATE?
          Like said, just an idea I do not know if it helps but I hope so.
          Good luck,
          Ebiwahnkenobi
            On 05/09/2006 at 09:49, xxxxxxxx wrote:
            Hi fuxy ,
            I think you have to set the container after setting it's data
            rd->SetContainer(bc);
            Ciao , Frank.
              On 05/09/2006 at 10:39, xxxxxxxx wrote:
              Hi Frank you won :)) . Thank you very much!!!
              Regards,
              fuxy
                On 05/09/2006 at 15:27, xxxxxxxx wrote:
                Hi ebiwahnkenobi, you won too, I had to use EventAdd() function...
                thanks again
                Regards,
                fuxy
