    Editor Translate/Scale/Rotate tools
    18 Posts 0 Posters 2.8k Views
      On 02/09/2006 at 14:08, xxxxxxxx wrote:
      Oops.. cross-posted :).
      Yeah, once you determine what the current camera/view scaling vector is, you multiply the matrix you're passing in by the inverse of that to keep your object the same size.
        On 02/09/2006 at 14:46, xxxxxxxx wrote:
        I don't quite follow you here. BaseView has two methods: GetMg() and GetMi() which return the Camera matrix and inverse matrix, respectively. I've tried multiplying the m.v1 (etc.) by Len(c.v1) where c is either the Camera matrix or inverse. That makes it look proper, but it still scales with the camera. Multiplying m by the camera matrix draws a right mess. 😉
        Now, there is GetViewParameter(), but I already get the view pixel dimensions from GetFrame(). I use that to
        determine 'rad' (a pixel value) for Circle2D().
        I should also mention that Circle3D() wants a matrix in World space. So it seems that the projection/camera is considered in the call.
        Still lost.
          On 02/09/2006 at 15:17, xxxxxxxx wrote:
          Ahh.. I'll try explaining better in an e-mail...
            On 02/09/2006 at 20:46, xxxxxxxx wrote:
            This old message:
            _despite Begin2d and End2D
            the display never seems to get updated
            ive gone through just about every way I can think of to get the display to update.
            as I said , the circle is drawn to the Basedraw bitmap and can only be seen by minimising and then maximimising cinama.
            so im at a loss here.
            maybe the EditorWindow class is in some way blocking this update?
            maybe this plugintool class is just not allowed to refresh the screen?
            thanks for any help
            Paul "baffled" Everett
            _
            Followed by the superbly explanatory:
            _
            Subject: working now
            Date: 9/14/2001 3:55 PM GMT
            thanks David :)_
            I'm having this problem as well - only orthographic views - and only some of them. It is so heartwarming to see that the solution was given for posterity (in invisible ink requiring lemon juice LISP code). Tell me the solution, please (this is not directed to you, Keith). Gad - it should be MANDATORY that solutions are posted for everyone either directly or on request. If this continues, I'm moving to Maya...
            Robert
              On 07/09/2006 at 23:53, xxxxxxxx wrote:
              Perhaps the old post about camera projections will help clear this up? <[URL-REMOVED]> Unfortunately I don't have the time right now to look into the math part of it.
                On 08/09/2006 at 00:09, xxxxxxxx wrote:
                As noted in my other thread, I cannot fathom why a 2D draw (based upon the screen pixels of the view) would be in any way affected by projection (ever!). Sometimes I get the 2D circle, most times not - especially not in axonometric views. OpenGL or Software modes don't make a difference.
                I can see how the 3D draws could be affected by the projection considering that they don't have the same 'z-distance' criteria as perspective projection. In that case, I'll have to experiment with the code in the link (and in the documentation).
                Nonetheless, one would assume that 2D drawing would be ubiquitous despite the active view unless there is some mitigating factor involved. I have been on the edge of providing the tool code in full to support to see if the error is obvious. May I do this after full investigation?
                  On 08/09/2006 at 00:14, xxxxxxxx wrote:
                  (Code is always welcome! As usual, make it as short a snippet as possible but not shorter.)
                    On 08/09/2006 at 10:51, xxxxxxxx wrote:
                    Here's the ToolData::Draw() code and one of the Control draw methods, some stuff removed for clarity, but still whopping (hey, my tool plugin is 2000 lines of code and growing).
                    // ToolData.Draw
                    LONG IPPTool::Draw(BaseDocument* doc, BaseContainer& data, BaseDraw* bd, BaseDrawHelp* bh, BaseThread* bt, LONG flags)
                         LONG     drawFlags;
                         // Draw Operation Controls
                         if (selectedBP)
                              if          (operation == IPTOP_ROTATE)          DrawRotateControl(bd, bh);
                              else if (operation == IPTOP_TWIST)          DrawTwistControl(bd, bh);
                              else if (operation == IPTOP_SCALE)          DrawScaleControl(bd, bh);
                              else if (operation == IPTOP_TRANSLATE)     DrawTranslateControl(bd, bh);
                              drawFlags =     DRAW_HANDLES;
                         else     drawFlags =     DRAW_AXIS|DRAW_HANDLES;
                         // Only draw into active view
                         if (bd != doc->GetActiveBaseDraw())     return drawFlags;
                         // Go no further if in dragMode for operation
                         if (dragMode)                              return drawFlags;
                         // This allows click-deselection
                         hilitedOP =                                   NULL;
                         hilitedBP =                                   NULL;
                         // From here on in, only draw highlighting (if R9.0+)
                    #ifdef C4D_R9
                         if (!(flags & DRAWFLAGS_HIGHLIGHT))     return drawFlags;
                    #endif
                         // Mouse outside of Editor view
                         if (mouseX < 0.0)                         return drawFlags;
                         // Add IPP objects under cursor to selection list
                         AutoAlloc<C4DObjectList>               objList;
                         if (!objList)                              return drawFlags;
                         if (!SelectionListCreate(doc, NULL, bd, mouseX, mouseY, NULL, objList))     return drawFlags;
                         LONG               cnt =                    objList->GetCount();
                         if (!cnt)                                   return drawFlags;
                         // The rest of the code involves Polygon/BoundingBox highlighting.
                         // This is working in all views.
                         // Though I do note that when the operation draws (above),
                         // the BoundingBox highlighting is no longer in the highlight color.
                         // So, I've included just a section where a bounding box is highlighted
                         else
                              hilitedOP =               obj;
                              hilitedBP =               ippTag->GetDataInstance()->GetObjectLink(IPPOBJECT_ROOTBONE, doc);
                              if (!hilitedBP)          return drawFlags;
                    #ifdef C4D_R9
                              bd->LineZOffset(32);
                    #endif
                              bd->SetTransparency(100);
                              Matrix          mg =     hilitedBP->GetMg();
                              // Global position
                              mg.off =               mg*hilitedBP->GetMp();
                              // 'arbitrary cubic form to match bounding box
                              Vector          rad =     hilitedBP->GetRad()*2;
                              mg.v1 *=               rad.x;
                              mg.v2 *=               rad.y;
                              mg.v3 *=               rad.z;
                              // color[0] is from the Vector color[4] array of colors used in polygon highlighting
                              bd->Box3D(mg, 0.5, color[0]);
                    #ifdef C4D_R9
                              bd->LineZOffset(0);
                              return drawFlags|DRAW_HIGHLIGHTS;
                    #else
                              return drawFlags;
                    #endif
                         return drawFlags;
                    // IPPTool.DrawRotateControl
                    void IPPTool::DrawRotateControl(BaseDraw* bd, BaseDrawHelp* bh)
                         Matrix m =          selectedBP->GetMg();
                         Vector     ctr =     bd->WS(m.off);
                         if (ctr.z <= 0.0)     return;
                         // BaseView dimensions
                         LONG left, top, right, bottom, width, height;
                         bd->GetFrame(&left;, &top;, &right;, &bottom;);
                         width =               right - left + 1;
                         height =          bottom - top + 1;
                         Real     rad =     (Real)((width > height)?(height>>2) :(width>>2));
                         // rad2 = 0.5 rad * ctr.z * scaling factor 0.0015
                         Real     rad2 =     ctr.z * (rad * 0.00075);
                         // Scale for PolygonObject
                         m.v1 =               !m.v1 * rad2;
                         m.v2 =               !m.v2 * rad2;
                         m.v3 =               !m.v3 * rad2;
                         // PolygonObject Color Properties
                         ObjectColorProperties     ocp;
                         ocp.usecolor =     ID_BASEOBJECT_USECOLOR_ALWAYS;
                         ocp.xray =          FALSE;
                    #ifdef C4D_R9
                    #endif
                         bd->SetTransparency(255);
                         // 'Sphere'
                         bd->SetPen(GetWorldContainer().GetVector(WPREF_SELECT_AXIS_COL));
                         bd->Circle2D(ctr.x, ctr.y, rad);
                         // 'Rings'
                         // Z-Axis
                         ocp.color =          GetWorldContainer().GetVector(WPREF_ZAXIS_COL);
                         rotatObj->SetColorProperties(&ocp;);
                         rotatObj->SetMg(m*MatrixRotX(Rad(-90.0)));
                    #ifdef C4D_R9
                         bd->DrawPolygonObject(bh, rotatObj, 0L);
                         bd->LineZOffset(0);
                    #else
                         bd->PolygonObject(bh, rotatObj, 0L);
                    #endif
                      On 08/09/2006 at 11:10, xxxxxxxx wrote:
                      Eh hem. Well, I found the first mistake - that helps the missing Circle2D partially. I though that I had double-checked this, but too many hours of working can play tricks on the mind. How about 'bd->SetTransparency(0)' instead of (255). Still not showing under every circumstance and most of the axonometric/orthographic views.
                        On 08/09/2006 at 12:19, xxxxxxxx wrote:
                        Next solution. Removing this for the controls draws them in any view:
                        Seems that this is true for certain situations in axonometric/orthographic views. Now it's just a matter of keeping the control sizes the same relative to the screen space.
                        Also, I still haven't received any official information on how to factor in camera zoom/focal length with respect to control size.
                          On 09/09/2006 at 14:48, xxxxxxxx wrote:
                          Eureka!!!!!!!!!! ;D
                          For posterity and for the benefit of others to relieve their suffering in purgatory, I present code which ACTUALLY works in all projections, all views, all cameras for displaying Tool controls (similar to Cinema 4D's) using BaseDraw:
                          First off, implement these. ScreenToWorld is useful for drawing, but WorldToScreen may prove useful for picking.
                          // IPPTool.WorldToScreen (see BaseView.GetViewParameter)
                          Vector IPPTool::WorldToScreen(const Vector& pp, BaseDraw* bd, LONG projection)
                               Vector     p =                    pp*bd->GetMi();
                               Vector     off, scale, scalez;
                               bd->GetViewParameter(&off;, &scale;, &scalez;);
                               if (projection == Pperspective)
                                    Real     nz =     (p.z <= 0.0) ? 20.0 : 1.0/(p.z + 0.05);
                                    p.x =               p.x*scale.x*nz+off.x;
                                    p.y =               p.y*scale.y*nz+off.y;
                                    return p;
                               p.x =     (p.x*scale.x)+off.x;
                               p.y =     (p.y*scale.y)+off.y;
                               switch (projection)
                                    case Pmilitary: case Pfrog: case Pbird: case Pgentleman:
                                    p.x +=     p.z*scale.x*scalez.x;
                                    p.y -=     p.z*scale.y*scalez.y;
                                    break;
                               return p;
                          // IPPTool.ScreenToWorld (see BaseView.GetViewParameter)
                          Vector IPPTool::ScreenToWorld(const Vector& pp, BaseDraw* bd, LONG projection)
                               Vector p =                    pp;
                               switch (projection)
                                    p.x -= p.z*scale.x*scalez.x;
                                    p.y += p.z*scale.y*scalez.y;
                                    break;
                               p.x = (p.x-off.x)/scale.x;
                               p.y = (p.y-off.y)/scale.y;
                               if (projection==Pperspective)
                                    Real nz = p.z + 0.05;
                                    p.x *= nz;
                                    p.y *= nz;
                               return p*bd->GetMg();
                          Then do your controls like so:
                               LONG     proj =     bd->GetProjection();
                               Vector     a =          ScreenToWorld(ctr, bd, proj);
                               Vector     b =          ScreenToWorld(Vector(ctr.x+rad*0.5, ctr.y, ctr.z), bd, proj);
                               Real     rad2 =     2.0 * Len(b-a);
                               if (proj == Pfrog)
                                    m.v2 =               !m.v2 * rad2 * 0.333;
                               else
                          #ifdef C4D_R9
                          #endif
                               bd->SetTransparency(0);
                               // 'Sphere'
                               // 'Rings'
                               // X-Axis
                               ocp.color =          GetWorldContainer().GetVector(WPREF_XAXIS_COL);
                               rotatObj->SetMg(m*zrotMat);
                          #ifdef C4D_R9
                          #else
                          #endif
                               // Y-Axis
                               ocp.color =          GetWorldContainer().GetVector(WPREF_YAXIS_COL);
                               rotatObj->SetMg(m);
                          #ifdef C4D_R9
                          #else
                          #endif
                               // Z-Axis
                               rotatObj->SetMg(m*xrotMat);
                          #ifdef C4D_R9
                               bd->LineZOffset(0);
                          #else
                          #endif
                          For non-radial controls (translate/scale), rad2 = Len(b-a). This considers projection, camera, view, focus, zoom - so simple and you wonder why NOONE (especially the developers) can provide this for .... sake!!
                          Thank you, thank me...
                            On 09/09/2006 at 18:04, xxxxxxxx wrote:
                            Slight modification to ScreenToWorld() and WorldToScreen() to support pre-R9.0 versions:
                            replace:
                            with:
                            #ifdef C4D_R9
                            #else
                                 bd->GetParameter(&off;, &scale;, &scalez;);
                            #endif
                            More information on the polygon objects used for the control interface. I built the controls in C4D and exported as Wavefront so that the extents were 1x1x1 (the radius is 0.5). The polygon objects are cone (translate), cube (scale) and ring (rotate/twist). These were setup as Vector arrays for the points and LONG arrays for the polygons in a header (could be done with either reading/parsing the Wavefront .obj files or reading some other proprietary format). The objects are created/stored in the constructor and verified in the ToolData::Init() so that they must exist whenever the tool is activated.
                            zrotMat is a MatrixRotZ(Rad(90)) matrix
                            xrotMat is a MatrixRotX(Rad(-90)) matrix
                            These two matrices 'orthogonalize' the polygon objects to the particular local axis.
