    help with undo needed
    5 Posts 0 Posters 393 Views
      On 17/08/2006 at 01:20, xxxxxxxx wrote:
      Cinema 4D Version:   9.6
      I am new to coffee programming and have some problems with a script I wrote which I want to offer a proper undo. The script deletes several objects in the scene. When I want to undo the script action I have to do an undo for every deletion the script did. object by object.
      What I want is that the whole script action will be just one undo step.
      I tried with startundo(), endundo() and several addundo()'s in between but it does not work.
      So how can I combine several deletions in just one undo step?
        On 19/08/2006 at 04:49, xxxxxxxx wrote:
        Since I got no reply yet I try it another way to explain my problem:
        In the code beneath I delete 2 objects. When I undo the action I have to do undo twice for every deleted object. How can I combine the 2 undo's into one? Can you maybe give me an example with the code snippet beneath?
        main(doc,op)
                doc->StartUndo();
                var op2 = op->GetNext();
                doc->AddUndo(UNDO_OBJECT,op);
                CallCommand(12109); // Delete (Selected Object)
                doc->SetActiveObject(op2);
                doc->AddUndo(UNDO_OBJECT,op2);
                doc->EndUndo();
          On 19/08/2006 at 05:39, xxxxxxxx wrote:
          Have you tried replacing UNDO_OBJECT with UNDO_OBJECT_DEL?
            On 19/08/2006 at 05:42, xxxxxxxx wrote:
            yes i tried it and all other sorts of stuff but nothing worked as I want it to work. maybe this undo thing is limited within a script? I dunno.
              On 19/08/2006 at 08:23, xxxxxxxx wrote:
              It is possible as I haven't had any difficulties in doing multiple AddUndo()s in COFFEE - but this is using v6.3 and as a plugin. So, it could be the script facet or the version. Have you tried this as a basic menu plugin to see if it has the same problem?
