    Strange Crash Problem
    7 Posts 0 Posters 655 Views
      On 11/08/2006 at 10:42, xxxxxxxx wrote:
      Cinema 4D Version:   9.603
      Hi all
      i try to make a copy paste system for polygons.
      And i'm having some stability problems.
      Here is the code of the "copy" part. Sorry, i couln't simplify it anymore so that it still crashes.
      #include "c4d.h"
      #include "c4d_symbols.h"
      struct Clipboard
      ~Clipboard() { TakeObjects(NULL); }
      AutoAlloc<AtomArray> array;
      void TakeObjects( AtomArray* a );
      void Clipboard::TakeObjects( AtomArray* a )
      if( !array ) return;
      // free all stored objects
      array->FilterObjectChildren();
      for( LONG i=0; i<array->GetCount(); ++i )
          BaseObject* op = static_cast<BaseObject*>( array->GetIndex(i) );
          BaseObject::Free( op );
      array->Flush();
      GeAssert( array->GetCount()==0 );
      // copy pointers from a to array
      if( a ) a->CopyTo( array );
      static Clipboard *g_clip = NULL;
      void FreeClipboard()
      gDelete( g_clip );
      Clipboard* GetClipboard()
      if( !g_clip ) {
          g_clip = gNew Clipboard;
      return g_clip;
      Bool DoCopy( BaseDocument* doc )
      Clipboard* clip = GetClipboard();
      if( !clip ) return TRUE;
      AutoAlloc<AtomArray> active;
      doc->GetActivePolygonObjects( *active, TRUE );
      if( active->GetCount()>0 )
          ModelingCommandData md;
          md.op = NULL;
          md.arr = active;
          md.doc = doc;
          md.result = NULL;
          md.mode = 0;
          md.flags = 0;
          md.result = NULL;
          SendModelingCommand( MCOMMAND_SPLIT, md );
          clip->TakeObjects( md.result );
      else clip->TakeObjects( NULL );
      class MenuTest : public CommandData
                virtual Bool Execute(BaseDocument *doc);
      Bool MenuTest::Execute(BaseDocument *doc)
      DoCopy( doc );
      Bool RegisterMenuTest(void)
           // decide by name if the plugin shall be registered - just for user convenience
           String name=GeLoadString(IDS_MENUTEST); if (!name.Content()) return TRUE;
           return RegisterCommandPlugin(1000956,name,0,"icon.tif","C++ SDK Menu Test Plugin",gNew MenuTest);
      //In main.cpp:
      void FreeClipboard();
      void PluginEnd(void)
      FreeClipboard();
      This code can crash reproducable when you do the following:
      Create c4d_debug.txt file, so C4d runns in debug mode.
      Run C4d.
      Make a cube.
      Make Editable.
      Make a HNWeightTag ( use hn weight tool on some edges )
      Select some polys
      Call the plug
      Quite Cinema
      BOOM... wtf..
      it only crashes if you run in debug mode, and have the HN tag. I suspect some memory becomes corrupted somehow.
      Okay this crash happens when you quit. But i'm also having other crashes which are harder to reproduce.
      I have no idea what is going on. Help ??!!
        On 11/08/2006 at 12:31, xxxxxxxx wrote:
        hmm... if i use this...
        array->Flush();
            BaseTag *t;
            while( t = op->GetTag( Tsds ) )
              t->Remove();
              BaseTag::Free( t );
        ... the entire plug appears to work just fine.
        best regards
        Michael
          On 17/08/2006 at 23:59, xxxxxxxx wrote:
          bump
          uhm.. mikael, can you reproduce ?
            On 18/08/2006 at 14:05, xxxxxxxx wrote:
            Sorry, I thought that the last piece of code you posted was a fix. Perhaps I should take the time to actually read this thread through now... 🙂
              On 19/08/2006 at 10:21, xxxxxxxx wrote:
              Yes please check it out. The code is no fix, it removes the HNWeight-Tags which seem to cause the problems. It should work with all kind of tags though.
                On 28/08/2006 at 01:31, xxxxxxxx wrote:
                You should use:
                C4DPL_ENDACTIVITY
                in PluginMessage otherwise (from the sdk docs) :
                Sent to all plugins before any PluginEnd() has been called. This allows you to close dialogs, end threads, delete temporary/undo buffers etc. In PluginEnd() it might crash as some resources from other plugins might already be freed.
                HTH.
                  On 28/08/2006 at 02:53, xxxxxxxx wrote:
                  Thanks David.
