    Connect, how to?
    4 Posts 0 Posters 410 Views
      On 02/08/2006 at 05:31, xxxxxxxx wrote:
      Cinema 4D Version:   9.5
      Platform:      Mac OSX  ;
      Is there any way to perform the Connect command on a polygonal object, in COFFEE? I see no such command in the SendModelingCommand command.
      And the CallCommand(12144) does nothing, even if I have the relevant objects selected.
      Rui Batista
        On 02/08/2006 at 09:32, xxxxxxxx wrote:
        I use 12144 in Script and it works. Are you sure the objects are selected (either manually or via coffee) before the command is called?
        Lennart
          On 02/08/2006 at 11:34, xxxxxxxx wrote:
          should be MCOMMAND_JOIN for sendmodelingcommand
            On 04/08/2006 at 02:19, xxxxxxxx wrote:
            Yes, they are all selected.
            And the MCOMMAND_JOIN is not documented in the COFFEE SDK 😞
            I will give it a try. Thank you 🙂
            Rui Batista
