    Reading out Tpointselection
    5 Posts 0 Posters 465 Views
      On 14/07/2006 at 16:13, xxxxxxxx wrote:
      Cinema 4D Version:   9.6 Demo
      HI !
      mayby someone can help me. i want to read out the points in a Tpointselection tag. but have no idea how to do that.
      main(doc,op)
           var tag = op->GetFirstTag();
           tag = tag->GetNext();
           var Type = tag->GetType();
           println(Type); // 5674 -> Tpointselection
           var name = tag->GetName();
           println(name); // "MySel1"
      Any idea how to move on? Where are the points in the selectionTag?
      Thx!
        On 14/07/2006 at 23:22, xxxxxxxx wrote:
        First, I would never depend upon a tag being in a particular place within the object's tag list. Do this:
        for (tag = op->GetFirstTag(); tag; tag = tag->GetNext())
        if (instanceof(tag, Tpointselection))
        var select = ((PointSelectionTag* )tag)->GetSelection();
        select is a BaseSelect class which contains an array which is the size of the number of points of the object. The points covered by the PointSelectionTag will be IsSelected(), the others not - think of this as an array of 1's and 0's. The selected points are 1, the others are 0. That is how a BaseSelect works, basically (same for PolygonSelectionTags as well). You can get the number of selected points in the array with select->GetCount().
        = select->IsSelected(x)). You'll need to get the object's vertex with PointObject->GetPoint(x). Now you have a one-one correspondence between selected points (IsSelected(x)) and the actual vertex (GetPoint(x)).
          On 15/07/2006 at 11:35, xxxxxxxx wrote:
          I say THX Kuroyume! now it should work.
            On 15/07/2006 at 13:26, xxxxxxxx wrote:
            Another short question.
            Is it possible to export model/tag data via coffee in Cinema4D 9.6 DEMO!! ?? I dont get the filename or basefile classes to work... mayby someone can help at that point??? please 🙂
            thx!
              On 15/07/2006 at 17:46, xxxxxxxx wrote:
              i fixed that problem. !
