    I got error from Xcode when compiling
    8 Posts 0 Posters 825 Views
      On 03/06/2006 at 04:57, xxxxxxxx wrote:
      Cinema 4D Version:   9.6
      Platform:      Mac OSX  ;
      Hi all,
      i got an error when trying to compile nota on Xcode
      here the screenshot:
      http://www.parmi.tv/NotaError.jpg![](http://www.parmi.tv/NotaError.jpg)
        On 06/06/2006 at 06:15, xxxxxxxx wrote:
        Can Someone help me?
        Renato
          On 08/06/2006 at 09:16, xxxxxxxx wrote:
          Help!
            On 08/06/2006 at 10:02, xxxxxxxx wrote:
            Could it be something with the file permissions of the path listed (libmathCommon)? Can you access the file from a terminal window?
              On 10/06/2006 at 17:51, xxxxxxxx wrote:
              uhm..
              thanks Mikael for this info.. in fact i need to understand privilege on osx. 🙂
              i'll tell you, thanks for now.
              Renato
                On 17/06/2006 at 06:59, xxxxxxxx wrote:
                If you still have problems with this.. well.. don't know about this math lib. But the "multiple definition of symbol" usually appears when there are two .cpp files, where each contains the definition of a certain function. For example
                In file foo.cpp:
                void f() {
                GeDebugOut("foo");
                In file bar.cpp:
                void f() {
                GeDebugOut("bar");
                This will create such an error because both f's have the same signature.
                  On 17/06/2006 at 14:37, xxxxxxxx wrote:
                  Thanks, i'll check 🙂
                  Renato T.
                    On 17/06/2006 at 18:29, xxxxxxxx wrote:
                    Thank to you i found the error.. 2 main.cpp 1 notashader.cpp and not nota.cpp in the project..
                    this is really lame
                    Thank 🙂
                    Renato
