    Render resolution
    5 Posts 0 Posters 408 Views
      On 01/06/2006 at 07:34, xxxxxxxx wrote:
      Cinema 4D Version:   9.6
      Language(s) :
      I would like to change the render resolution through an input in my PostEffect Plugin, but GetActiveDocument()->GetActiveRenderData()->GetData()->SetLong(RDATA_XRES,value) doesn't change the resolution.
      An idea for me ?
      Thanks in advance,
      Vincent
        On 02/06/2006 at 16:01, xxxxxxxx wrote:
        You have to set RDATA_RESOLUTION to 0 (manual), or to one of the other values if you want to pick a preset resolution.
        - Rick
          On 09/06/2006 at 02:20, xxxxxxxx wrote:
          Hi Rick,
          I'm doing that in the method GetDParameter of my plugin, I call like that:
          rdata.SetLong(RDATA_RESOLUTION,0);
          rdata.SetLong(RDATA_XRES,m_DisplayImageWidth);
          but it doesn't work too. Should I do that somewhere else ?
          Thanks lot !
          Vincent
            On 12/06/2006 at 12:42, xxxxxxxx wrote:
            Oh, looks like you're in C++ - I haven't played with this there. Sorry.
            This COFFEE works for me, if that helps:
            var rd = doc->GetFirstRenderData();
            var bc = rd->GetContainer();
            bc->SetData(RDATA_RESOLUTION,6);
            bc->SetData(RDATA_XRES,720);
            bc->SetData(RDATA_YRES,486);
            bc->SetData(RDATA_XPIX,10);
            bc->SetData(RDATA_YPIX,11);
            bc->SetData(RDATA_FRAMERATE,30);
            rd->SetContainer(bc);
              On 15/06/2006 at 22:50, xxxxxxxx wrote:
              To make the call like that you would have to do GetActiveDocument()->GetActiveRenderData()->GetData Instance ()->SetLong(RDATA_XRES,value), otherwise the changes are lost.
