    MergeDocument()
    9 Posts 0 Posters 883 Views
      On 06/05/2006 at 05:47, xxxxxxxx wrote:
      Cinema 4D Version:   9.5
      Platform:   Windows  ; Mac  ;
      I tried to merge a scene into the currently active document and MergeDocument returns TRUE, but nothing is merged into the scene. 😕
      Anybody knows how to use MergeDocument() or why it´s not workign?
      BaseDocument *doc=GetActiveDocument();     if (!doc) return FALSE;
                     MergeDocument(doc,this->file,SCENEFILTER_MERGESCENE,NULL);
        On 16/05/2006 at 00:47, xxxxxxxx wrote:
        So, doesn´t it work or am I doing sth wrong?
        How is one supposed to develop when you need to beg for an answer?
          On 16/05/2006 at 06:35, xxxxxxxx wrote:
          MergeDocument() is new to the R9.5 SDK, so I've never used it. You're probably one of the first to do so. 🙂
          What you're doing looks proper from reading the documentation. Does the loaded document show anywhere (unmerged, for instance) or does it just not load at all?
            On 16/05/2006 at 06:41, xxxxxxxx wrote:
            Hi Kuro,
            it simply doesn´t load at all. I don´t get any memory leaks but the function returns TRUE! It really seems to do nothing! 😞
              On 16/05/2006 at 08:22, xxxxxxxx wrote:
              What kind of document is it? A .c4d I would suppose. Have you tried other files and file types, .obj for instance?
              Looking at 'c4d_basedocument.cpp', it appears that SCENEFILTER_MERGESCENE is already OR'd into the flags. Try it without any flags (0L), if you haven't already.
                On 16/05/2006 at 08:50, xxxxxxxx wrote:
                yep, it is c4d. Also tried other formats. And I of course already tried any kind of FLAG combination already. 🙂 No difference though. 😞
                  On 16/05/2006 at 13:29, xxxxxxxx wrote:
                  I'm sorry, the docs are a bit misleading. In my experiments I need to have SCENEFILTER_OBJECTS|SCENEFILTER_MATERIALS in order to make both LoadDocument() and MergeDocument() actually do anything. This is the code I used:
                      Filename fn1;
                      fn1.FileSelect();
                      BaseDocument* doc1 = LoadDocument(fn1, SCENEFILTER_OBJECTS|SCENEFILTER_MATERIALS, NULL);
                      Filename fn2;
                      fn2.FileSelect();
                      MergeDocument(doc1,fn2, SCENEFILTER_OBJECTS|SCENEFILTER_MATERIALS,NULL);
                      InsertBaseDocument(doc1);
                      EventAdd();
                    On 16/05/2006 at 13:33, xxxxxxxx wrote:
                    Thanks Mikael! Now I see what LoadDocument has to do with it! Great, will try that. Thanks finally!
                      On 14/06/2009 at 11:50, xxxxxxxx wrote:
                      Just found this solution, but i'd like to understand why i need to use LoadDocument and cant use the current ActiveDocument as the base?
                      Ello
