    Crash on GetNext()!!!
    20 Posts 0 Posters 2.2k Views
      On 05/05/2006 at 01:28, xxxxxxxx wrote:
      hmm, maybe I got it in the wrong direction? Your statements seem feasible. I got to get that book again, not that my mind plays tricks with me and I am pointing to the exact opposite direction here and Ben curses me for this and I die a painful death. 😄
      My brother must have this lying around anywhere, so I´ll be checking this once I visit him again and let you know about it.
      About new C++ standard in the works - there is? I haven´t heard of it, but yikes! hits the spot very well. 😄
      My brother is also Java and C++ programmer btw. (for Volkswagen). I seem to always sourround myself with guys like you...tss ;-D
        On 05/05/2006 at 01:30, xxxxxxxx wrote:
        Yep, C++ is weird - which is why I skipped class. Understanding how a computer works and how a language implements this knowledge are two different things, I suppose. This may be why Assembly is appealing to some - the specifications and results are about as direct as you can achieve without doing the electronics yourself. 🙂
        Would this be the book:
        "Effective C++ : 55 Specific Ways to Improve Your Programs and Designs (3rd Edition) (Paperback)"
          On 05/05/2006 at 01:31, xxxxxxxx wrote:
          yep, this should be the book! Although for me it was 50 ways to improve your programs and designs (I had the 2nd Edition then I guess). 🙂
            On 05/05/2006 at 01:38, xxxxxxxx wrote:
            Just wanted to add, (void* )0 seems to be the C macro you´re talking about right?
            I don´t know why C++ does not use NULL like in Smalltalk where it´s a specially defined NULL-object that you can refer to instead of a numeral representation. Then we wouldn´t have to discuss this. 🙂
            And I think Java does not need to worry about all this at all? But I don´t know nothing about Java actually, only that you don´t have to worry about memory and pointers.
              On 05/05/2006 at 02:05, xxxxxxxx wrote:
              Yes, the (void* )0 was a C implementation of NULL - interesting, but it means a conversion from a defined pointer type to void - ugly ain't it. 🙂
              Well, this was the 'decided upon' definition of 'NULL' for pointers way back, I guess. Whoever made the decision decided that the memory address of an unset pointer should be equal to zero - this may have its roots in assembly (it has been quite some time). The problem isn't the standard notion of null pointer equals zero as much as how it gets interpreted into each language based upon its syntax and purpose.
              Java does indeed have a null reference. You do have to worry about class allocation (new) and validity (delete) just as in C++. Even though references to instances are handled automatically by garbage collection (when there are none, the memory is released), the references to them are still subject to validation. Most of the time, this is not a concern since you may have members still referencing and the instance will persist, but if you are getting the instance reference from, say, a method, you might want to check.
                On 05/05/2006 at 02:11, xxxxxxxx wrote:
                hihi, yep 🙂
                > Quote: Java does indeed have a null reference. You do have to worry about class allocation (new) and validity (delete) just as in C++. Even though references to instances are handled automatically by garbage collection (when there are none, the memory is released), the references to them are still subject to validation. Most of the time, this is not a concern since you may have members still referencing and the instance will persist, but if you are getting the instance reference from, say, a method, you might want to check.
                Ah I see. Well, that sounds way easier though. I´ve been interested in Java since I´ve heard that ZBrush is coded in Java, which sounds like Java can be effectively used to create such applications (and I am thinking about writing sth like ZBrush just for learning purposes...darn, where is Father time?).
                Samir
                  On 05/05/2006 at 02:18, xxxxxxxx wrote:
                  All of this is interesting, if not off topic. 🙂
                  It is interesting to note why 0 was used. At some point, someone was realizing that memory references (pointers) must become invalid for one reason or another (during initialization or when the memory is released). And a value had to be established (since memory addresses are just numbers). -1 might have been a candidate, but think of the consequences. -1 in 16-bit is 0xFFFF, which is a possibly valid 32-bit address, 0x0000FFFF. And so on for memory address sizes. Any other value could lead to similar results. But 0, to some extent, is 0 at all levels (though floating point has the odd distinction of 0 and -0 (because of the sign bit)).
                  This link is interesting (C reference) : Null Pointers
                  And this supports your understanding: C++ Null Pointers
                  I agree that unitialized pointers are not 'unset' pointers. When you initialize pointers, it should be to NULL (and I never use 0 in this case, oddly enough).
                  The things we learn...
                    On 05/05/2006 at 02:27, xxxxxxxx wrote:
                    Thanks for the links. Will check these out.
                    Off topic? Naaahh. 😄
                      On 05/05/2006 at 06:36, xxxxxxxx wrote:
                      Hi all,
                      Well, I found my problem!!!
                      I somewhat missed the following statement in the SDK doc:
                      The compiler options for Pointer-to-member representation must be set to "General-Purpose Always" and "Point to Single-Inheritance Classes" in C++ tab/C++ language (/vmg /vms). If not set the plugin will crash instantly!
                      Well, the plugin was able to do a lot of things (volumetric shaders, creating objects, some motion handler, etc.) but it crashed on several things...so it was not crashing instantly unfortunately (it would have been easier to find the error in this case...)
                      Now everything is working perfectly!
                      Best regards,
                      Ben
                        On 05/05/2006 at 06:52, xxxxxxxx wrote:
                        great that it wasn´t anything anybody suggested. 😄
                        Thanks for letting us know and glad you found the prob.
                        Best
                        Samir
                          On 05/05/2006 at 10:34, xxxxxxxx wrote:
                          Very good, Ben!
                          Note that it is a good idea to use one of the included projects (either the api_lib or cinema4dsdk) as a basis for your plugin's. Then these settings will be already proper.
