    GeExecuteProgram
    3 Posts 0 Posters 346 Views
      On 03/05/2006 at 00:05, xxxxxxxx wrote:
      Cinema 4D Version:   9x
      Hi all,
      I need to run the Vray.exe executable from my plugin.
      The bad is that i'm not able to pass parameters to this executable.
      es.
      c:\vray\bin\x86\vray.exe -scenefile=c:\path\VrayForC4d.exe
      I tried to fill the first argument need by GeExecuteProgram with the complete name with parameters but it's not working.
      any help?
      Thanks in advance
      Renato T.
        On 03/05/2006 at 03:02, xxxxxxxx wrote:
        As far as I can tell, GeExecuteProgram() does not take command line arguments, only two Filename classes: the executable and a file to be opened by the executable. Since the Filename class only represents a file path, other text would not work properly.
        If you can substitute a batch file for the executable, you may be able to get the command line arguments passed in that way.
          On 03/05/2006 at 17:23, xxxxxxxx wrote:
          Thanks Robert, it work 🙂
          Now will be good to include the vray's libs on my project but there are a some redefinition that gave me a lots errors.
