    basechannel?
    7 Posts 0 Posters 565 Views
      On 27/03/2006 at 03:14, xxxxxxxx wrote:
      Cinema 4D Version:   8.5
      Hi.
      Ive recently shifted to c++ from coffee, and find the 8.5 material system difficult to use... I need to create a new bitmap shader.  I can do it using basechannels, grabbing ,say, the color channel and reading/assignong its bitmap.    I know that basechannels are now old hat, but how do you create a new shader[xbitmap] and  then assign a new bitmap to it?  Can someone show me a quick example how to do this?
       The prob I have is the basecontainer IDs.  With basechannels  you can set a new filename for the InitTexture to find , but what  are the IDs for an xbitmap ?
      Is it okay to continue using basechannels? Will they suddenly be removed from future versions......?
      thanks for ANY help at all....
      tone.
        On 27/03/2006 at 09:21, xxxxxxxx wrote:
        Hi.
        I just need to understand the ethos of materials now...
        If you attach a new shader to a material,  how do you decide which material channel it is working for?  e.g. create a noise shader and apply it to the material`s color channel..
        anyone..........?
          On 29/03/2006 at 08:02, xxxxxxxx wrote:
          References to Shaders are now stored in BaseLinks. So you can just do mat->GetDataInstance()->GetLink( MATERIAL_COLOR_SHADER, doc, Xshader ) to get the shader in the color channel for example.
          The id's can be found in mmaterial.h in the resource/res/description folder.
          Some of the shader headers are in
          But most of them are in
          resource\modules\shader\res\description
          and
          modules\CINEMA 4D\sla\res\description
          Look for files like Xshadername.h
          The id's for the Bitmap shader are in
          resource/res/description/Xbitmap.h
          To give a channel a bitmap texture you would do something like:
          PluginShader* shd = PluginShader::Alloc(Xbitmap);
          shd->GetDataInstance()->SetFilename(BITMAPSHADER_FILENAME,"texture.jpg");
          mat->GetDataInstance()->SetLink( MATERIAL_COLOR_SHADER, shd );
          Of course, don't forget to check the result of allocations, delete shaders that are not needed anymore.. well you know.. all the memory management stuff that is not needed in coffee..
            On 30/03/2006 at 02:09, xxxxxxxx wrote:
            Thanks  Michael....
            I know you pros are generally too busy to help new starters with the basics, but this is much appreciated.
            cheers..
            tone.
              On 30/03/2006 at 07:39, xxxxxxxx wrote:
              Hmm..
              Sorry for sounding thick, but  I can use the above to make noise shaders etc. but cannot make a new LayerShader.   .
              I assume you use Insertshader to add layers to an Xlayer..   and then   link to a full-blown LayerShader...    but can`t seem to get it to work.
              cheers...
                On 30/03/2006 at 11:23, xxxxxxxx wrote:
                the Layershader is quite special. From the R9.5 SDK upwards, there is a library to deal with it. Look for lib_layershader, or so. If you can't find there what you need, i guess you are out of luck. InsertShader will not work i think.
                  On 30/03/2006 at 11:27, xxxxxxxx wrote:
                  Ah well..
                  can`t win em all......
                  ta.
